077 Spring Question #770610
08/10/10 11:54 AM
08/10/10 11:54 AM
New York
R/T1968R/T Offline OP
New York
Im running a .528 purple shaft. The cam is broken in already. I want to switch to the DC recommended 077 springs (which I already have new). I have heard bad things about the old mopar springs, however if I use them would there be to much pressure for a street driven car?
Re: 077 Spring Question [Re: R/T1968R/T] #770611
08/10/10 12:59 PM
08/10/10 12:59 PM
tboomer Offline
tboomer  Offline
Here is a for ya!! Zippy is the go to guy on the springs...He can help ya out! FWIW...I may have a set of those or maybe they are the 033 springs...I can't remember!!
Re: 077 Spring Question [Re: tboomer] #770612
08/10/10 04:42 PM
08/10/10 04:42 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
have you checked the current price on the 077 valve spring from mopar..make sure you are sitting down went you do....
Tony
70 AARCuda Vitamin C
Re: 077 Spring Question [Re: 70AARcuda] #770613
08/10/10 07:56 PM
08/10/10 07:56 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
There are much better springs on the market for your application. I had a new set of '077's' they were over 435#'s over the nose when I checked them. Dave
Re: 077 Spring Question [Re: quickd100] #770614
08/10/10 09:57 PM
08/10/10 09:57 PM
New York
New York
Dave, how many lbs. should they be?
Re: 077 Spring Question [Re: R/T1968R/T] #770615
08/10/10 10:22 PM
08/10/10 10:22 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
120-130 on the seat and 300-320 over the nose,IMO but give Comp Cams or another cam company for their recs. That's what they're in the business for. Dave
Re: 077 Spring Question [Re: quickd100] #770616
08/10/10 11:38 PM
08/10/10 11:38 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Factory spec is 405 at 1.500 but like Dave said, depending on your checking height/RR etc many times you'll find yourself with even higher pressure.
They're overkill, especially considering how gentle the MP lobe profiles are, that the 077 spring was always recommended for. If you call the tech line, recommendations may be slightly different than what is in the catalog or engine book
Rich H.
Esse Quam Videri
Re: 077 Spring Question [Re: quickd100] #770617
08/12/10 01:05 PM
08/12/10 01:05 PM
New York
New York
Dave, the 033 spring comes in at 120 / 310lbs. I have a set of these, what do you think?
Re: 077 Spring Question [Re: R/T1968R/T] #770618
08/13/10 07:17 AM
08/13/10 07:17 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Greg; If you are refering to the P3690933 street hemi spring they will probably work. CHECK for coil bind though at max lift. With the .028/.032 valve lash you sould be safe. Check everything first, if you need one spring as a checker before you buy a set shoot me a PM, I've got an extra. Dave
