Re: 077 Spring Question
[Re: tboomer]
#770612
08/10/10 04:42 PM
08/10/10 04:42 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
have you checked the current price on the 077 valve spring from mopar..make sure you are sitting down went you do....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: quickd100]
#770616
08/10/10 11:38 PM
08/10/10 11:38 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Factory spec is 405 at 1.500 but like Dave said, depending on your checking height/RR etc many times you'll find yourself with even higher pressure. They're overkill, especially considering how gentle the MP lobe profiles are, that the 077 spring was always recommended for. If you call the tech line, recommendations may be slightly different than what is in the catalog or engine book
Rich H.
Esse Quam Videri
[Re: quickd100]
#770617
08/12/10 01:05 PM
08/12/10 01:05 PM
Posts: 735 New York
R/T1968R/T
New York
Dave, the 033 spring comes in at 120 / 310lbs. I have a set of these, what do you think?
