I have ordered a timing chain cover from Mancini, not the Mopar but the Mancini version. Quality appears to be OK at first glence. I was wondering if any of you have used it and if you were happy with it?
I have noticed that there is no more shoulder to install the seal, I guess it is to allow replacement from the front side. I was wondering if the seal could get pushed out by crankcase / oil pressure since there is no more hard stop?
Is the new Mopar cover built the same way? Mancini 4 digit P/N are the same as the last 4 digit of Mopar P/N and I was wonderinf if the casting is the same? On some picture I found the Mopar cover appears to have 3 holes arround the seal, what are those for? Also, it appears that the space between the water pump and the cover is reduced???
I am just wondering if I should use the Mancini cover or not...
