Mancini timing chain cover small block #770452
08/10/10 01:38 AM
08/10/10 01:38 AM
Montreal PQ, Canada
74_360_Cuda Offline OP
Montreal PQ, Canada
I have ordered a timing chain cover from Mancini, not the Mopar but the Mancini version. Quality appears to be OK at first glence. I was wondering if any of you have used it and if you were happy with it?
I have noticed that there is no more shoulder to install the seal, I guess it is to allow replacement from the front side. I was wondering if the seal could get pushed out by crankcase / oil pressure since there is no more hard stop?
Is the new Mopar cover built the same way? Mancini 4 digit P/N are the same as the last 4 digit of Mopar P/N and I was wonderinf if the casting is the same? On some picture I found the Mopar cover appears to have 3 holes arround the seal, what are those for? Also, it appears that the space between the water pump and the cover is reduced???
I am just wondering if I should use the Mancini cover or not...
Re: Mancini timing chain cover small block [Re: 74_360_Cuda] #770453
08/10/10 07:18 AM
08/10/10 07:18 AM
South Dakota
W
wireweld Offline
wireweld  Offline
W
South Dakota
I used it on my sb and had no problems with sealing or anything else. Had to clean some flashing out but nothing else.
Re: Mancini timing chain cover small block [Re: wireweld] #770454
08/10/10 07:05 PM
08/10/10 07:05 PM
Montreal PQ, Canada
Montreal PQ, Canada
Thanks for the info, did you just drive the seal flush to the fwd face? Have you used sealant or anything?
Re: Mancini timing chain cover small block [Re: 74_360_Cuda] #770455
08/10/10 07:45 PM
08/10/10 07:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
At some point the OEM timing cover was setup the same way. My 65 has a lip, my 87 doesn't.
Don't be the exception.
Re: Mancini timing chain cover small block [Re: Supercuda] #770456
08/10/10 09:26 PM
08/10/10 09:26 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Yes, in the 80's they went to the outside mounted front seal, permits you to change the seal without pulling the front of the motor off. There is a lip down in the bore, IIRC, the seal will bottom out on the lip before the front of the seal can get flush with the cover. Flush = damaged seal. Just put some RTV around the bore before you install the new seal, and it should stay put until you take it out.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Mancini timing chain cover small block [Re: GO_Fish] #770457
08/10/10 10:28 PM
08/10/10 10:28 PM
Montreal PQ, Canada
Montreal PQ, Canada
No lip in the bore on the Mancinin version... should I slightly recess the seal into the bore then?
Re: Mancini timing chain cover small block [Re: 74_360_Cuda] #770458
08/20/10 04:25 AM
08/20/10 04:25 AM
Red Lion, PA USA
scamper340 Offline
scamper340  Offline
Red Lion, PA USA
Did you ever find any more information on this? I'm in the same boat, bought a Mancini timing cover with no lip.
Re: Mancini timing chain cover small block [Re: scamper340] #770459
08/20/10 04:35 AM
08/20/10 04:35 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Late model seal has a front flange to set the depth..
Re: Mancini timing chain cover small block [Re: scamper340] #770460
09/23/10 09:11 AM
09/23/10 09:11 AM
Montreal PQ, Canada
Montreal PQ, Canada
I've just put it flush without problems.
I had to hand file a lot's of material to make the cover flush with the bottom of the block but so far no leak from the front seal so I guess the allignement with the crankshaft is ok...
