Tire recomendation's please need 29" slicks #770143
08/09/10 10:10 PM
08/09/10 10:10 PM
Redding,CA USA
440charger500 Offline OP
Redding,CA USA
Well its time for some new drag tires for the rear. My charger weighs 4000 lbs and runs 12.50-.60 et. I need some good tires that hook and will last me awhile. What do you guys think?
Re: Tire recomendation's please need 29" slicks [Re: 440charger500] #770144
08/09/10 10:37 PM
08/09/10 10:37 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
i run 29x9 Hoosiers
-7 inch wheel
-no tubes
-12.5 psi - 14 psi
i've put 25 passes on my car in the last 2 weeks at 2 different tracks. 60 fts. were 1.55(best) to a 1.61(worse). 2 different tracks, in really hot/humid conditions and on slippery/greasy race tracks.
-i'll be changing to a 8 inch wheel in the winter. i think the 7 inch wheel is wearing out the side walls prematurely. i'm only getting about 80 passes out of a set.-
*these are examples of my experiences- yours may vary !!
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: Tire recomendation's please need 29" slicks [Re: 440charger500] #770145
08/09/10 10:57 PM
08/09/10 10:57 PM
Locomotion Offline
Locomotion  Offline
Whatever tire you get, get the widest rim you can fit. The wider the rim in relation to the tread width, the more air pressure you can run. Adjust the air until you get a flat, even footprint and you will have a more stable sidewall at launch as well as the top end. Many Stock racers use a 10" rim with 9" slicks. We are limited to a 9"x30" tire. I run a lightweight Hoosier radial with 21.5lbs of air in my 3,540+ lb car. However, for bracket racing, a bias ply slick will be more consistent and may take a pound or so less air. Optimum tire pressure will vary in each application because of different vehicle weight, suspension, converter, gearing, etc.
Hoosier drag tire specs
Re: Tire recomendation's please need 29" slicks [Re: Locomotion] #770146
08/10/10 12:07 AM
08/10/10 12:07 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I used to run M/T slicks,and switched to Hoosier.A friend of mine was running Hoosiers,and getting more life out of them ,so I switched,and get better tire life.Plus you can run them tubeless without problems.
Re: Tire recomendation's please need 29" slicks [Re: Dunnuck Racing] #770147
08/10/10 01:07 AM
08/10/10 01:07 AM
Redding,CA USA
Redding,CA USA
I've been running the hoosier 27 11.50 QTP these are the only tires I have run. Maybe I'll look at the 29x10" QTP, I really dont want to run tubes if I dont have to. I believe my rims are 15x8" so I think they will work fine.
Re: Tire recomendation's please need 29" slicks [Re: 440charger500] #770148
08/10/10 01:45 AM
08/10/10 01:45 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I street drive/race w QTP`s in the 29x13.5 size on a 12" rim and they drive well on the street(dry weather of course)and hook good at the track. I`m going on two years and lots of street miles and there`s still good tread life left.
Re: Tire recomendation's please need 29" slicks [Re: 440charger500] #770149
08/10/10 03:28 PM
08/10/10 03:28 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Go with Phoenix.They last a LONG time and always hook well.Best results will be with the use of tubes.
Nautilus Racing-
Re: Tire recomendation's please need 29" slicks [Re: Chris2581] #770150
08/10/10 06:39 PM
08/10/10 06:39 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
with the above statement
I run 12-13 psi with 29.5 x 11.5 x 15
Re: Tire recomendation's please need 29" slicks [Re: roadhazard] #770151
08/10/10 07:57 PM
08/10/10 07:57 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No tire company, invests more R&D in their small tires than M/T.
Monte
383man [Re: Monte_Smith] #770152
08/10/10 09:30 PM
08/10/10 09:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran the 29 x 11.5 Hoosier QTP's on my 63 street/strip car and had a best 60 of 1.59 and they held up good but rubbed to much on turns. So when I looked for a 9" drag radial at 29 to 30" tall no one made any. Every 29 or 30" tall drag radials are at least 10.5 inches wide and sometimes rub a bit on turns in my stock wheelwell so I bought the 30 x 9 radial Hoosier slicks. My best 60 on them is a 1.57 and I have been driving them on the street since April 09 or over a year and they still have plenty of tread. They actually handle fine on the highway and the other roads. I even got caught in the rain once and I took it real easy for 40 miles with no problem. But I mean I took it real easy. Ron
Re: Tire recomendation's please need 29" slicks [Re: Chris2581] #770153
08/11/10 01:56 AM
08/11/10 01:56 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I have to agree here.
