Re: Tire recomendation's please need 29" slicks
[Re: 440charger500]
#770144
08/09/10 10:37 PM
08/09/10 10:37 PM
Posts: 535 Ohio
racerAL
Ohio
i run 29x9 Hoosiers -7 inch wheel -no tubes -12.5 psi - 14 psi i've put 25 passes on my car in the last 2 weeks at 2 different tracks. 60 fts. were 1.55(best) to a 1.61(worse). 2 different tracks, in really hot/humid conditions and on slippery/greasy race tracks. -i'll be changing to a 8 inch wheel in the winter. i think the 7 inch wheel is wearing out the side walls prematurely. i'm only getting about 80 passes out of a set.- *these are examples of my experiences- yours may vary !!
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: 440charger500]
#770145
08/09/10 10:57 PM
08/09/10 10:57 PM
Posts: 5,894 Florida
Locomotion
Whatever tire you get, get the widest rim you can fit. The wider the rim in relation to the tread width, the more air pressure you can run. Adjust the air until you get a flat, even footprint and you will have a more stable sidewall at launch as well as the top end. Many Stock racers use a 10" rim with 9" slicks. We are limited to a 9"x30" tire. I run a lightweight Hoosier radial with 21.5lbs of air in my 3,540+ lb car. However, for bracket racing, a bias ply slick will be more consistent and may take a pound or so less air. Optimum tire pressure will vary in each application because of different vehicle weight, suspension, converter, gearing, etc. Hoosier drag tire specs
[Re: 440charger500]
#770148
08/10/10 01:45 AM
08/10/10 01:45 AM
Thumperdart
State of confusion
I street drive/race w QTP`s in the 29x13.5 size on a 12" rim and they drive well on the street(dry weather of course)and hook good at the track. I`m going on two years and lots of street miles and there`s still good tread life left.
[Re: 440charger500]
#770149
08/10/10 03:28 PM
08/10/10 03:28 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Go with Phoenix.They last a LONG time and always hook well.Best results will be with the use of tubes.
[Re: Chris2581]
#770150
08/10/10 06:39 PM
08/10/10 06:39 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
with the above statement I run 12-13 psi with 29.5 x 11.5 x 15
[Re: Chris2581]
#770153
08/11/10 01:56 AM
08/11/10 01:56 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I have to agree here.
