Re: shot peening at home ?!?!
[Re: Stanton]
#764962
08/04/10 12:32 AM
08/04/10 12:32 AM
I think with enough air pressure it should work and besides what's the worst that's going to happen...get plugged. Give it a try.
[Re: JohnRR]
#764965
08/04/10 01:06 PM
08/04/10 01:06 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Prob going to use a few nozzles tho. Tell use what happens....lol
[Re: 474218]
#764969
08/04/10 07:48 PM
08/04/10 07:48 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
I would be a little skeptical on the outcome of that on the end of a hand drill> What is the operational RPM of those flapper wheels that would cause beneficial plastic deformation of the surface of the part? IF we are throwing around buzzwords, how about laser peening?
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: pishta]
#764970
08/04/10 08:54 PM
08/04/10 08:54 PM
Posts: 1,109 Hiram, Georgia
474218
Hiram, Georgia
Roto Peening is a standard repair, accomplished on high strength aircraft parts. If you looked at the second page you would have seen the strips that are use to determine proper saturation. In have done it numerious times and never had a problem.
[Re: Stanton]
#764971
08/04/10 09:02 PM
08/04/10 09:02 PM
Posts: 7,506 Az
Crizila
Az
Works good. I have done it with my Harbor freight cabinet W/siphon gun.
Fastest 300
[Re: Crizila]
#764972
08/04/10 10:30 PM
08/04/10 10:30 PM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Where'd you find the shot ??
Roto-peening ... I've got a lot of stuff I'd like to do. It goes a lot faster in the cabinet.
I'm not planning to do it to alter the strength of the metal, only for the cosmetic finish - much like they do to alternator and starter casings when they're remanufactured. Sandblasting and glass beads are great for material removal but peening gives a much nicer finish.
[Re: Stanton]
#764973
08/05/10 12:36 AM
08/05/10 12:36 AM
Posts: 7,506 Az
Crizila
Az
Been a while, but try www.tptools.com.
Fastest 300
