shot peening at home ?!?! #764961
08/04/10 12:02 AM
08/04/10 12:02 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Think you could do shot peening with a run-of-the-mill blast cabinet (like the Harbor Freight siphon units)? The beads are only .007" so its not like the thing has to suck bb's up the line!
Thoughts ...
Re: shot peening at home ?!?! [Re: Stanton] #764962
08/04/10 12:32 AM
08/04/10 12:32 AM
I think with enough air pressure it should work and besides what's the worst that's going to happen...get plugged. Give it a try.
Re: shot peening at home ?!?! [Re: ] #764963
08/04/10 08:53 AM
08/04/10 08:53 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I think the "worst" is wasting money on 50 pounds of shot. Since the stuff doesn't wear out its not something to easily resell.
Re: shot peening at home ?!?! [Re: Stanton] #764964
08/04/10 09:14 AM
08/04/10 09:14 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
A shot blast cabinet isn't a sand blast cabinet persay so I can't really see how well it would work?
Re: shot peening at home ?!?! [Re: JohnRR] #764965
08/04/10 01:06 PM
08/04/10 01:06 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Prob going to use a few nozzles tho. Tell use what happens....lol
Re: shot peening at home ?!?! [Re: moper] #764966
08/04/10 04:43 PM
08/04/10 04:43 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
So, you have a Rockwell Hardness Tester to see if it works or not?
Re: shot peening at home ?!?! [Re: moper] #764967
08/04/10 05:13 PM
08/04/10 05:13 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I'd be skeptical that you'd have enough force to actually do compression on the surface, which is required to get any benefit.
Re: shot peening at home ?!?! [Re: Stanton] #764968
08/04/10 06:43 PM
08/04/10 06:43 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
Have you given any thought to "Roto Peening"?
More information: http://www.3m.com/product/information/Roto-Peen.html
Click on more information.
Re: shot peening at home ?!?! [Re: 474218] #764969
08/04/10 07:48 PM
08/04/10 07:48 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I would be a little skeptical on the outcome of that on the end of a hand drill> What is the operational RPM of those flapper wheels that would cause beneficial plastic deformation of the surface of the part? IF we are throwing around buzzwords, how about laser peening?
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: shot peening at home ?!?! [Re: pishta] #764970
08/04/10 08:54 PM
08/04/10 08:54 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
Roto Peening is a standard repair, accomplished on high strength aircraft parts. If you looked at the second page you would have seen the strips that are use to determine proper saturation. In have done it numerious times and never had a problem.
Re: shot peening at home ?!?! [Re: Stanton] #764971
08/04/10 09:02 PM
08/04/10 09:02 PM
Az
Crizila Offline
Crizila  Offline
Az
Works good. I have done it with my Harbor freight cabinet W/siphon gun.
Fastest 300
Re: shot peening at home ?!?! [Re: Crizila] #764972
08/04/10 10:30 PM
08/04/10 10:30 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Where'd you find the shot ??
Roto-peening ... I've got a lot of stuff I'd like to do. It goes a lot faster in the cabinet.
I'm not planning to do it to alter the strength of the metal, only for the cosmetic finish - much like they do to alternator and starter casings when they're remanufactured. Sandblasting and glass beads are great for material removal but peening gives a much nicer finish.
Re: shot peening at home ?!?! [Re: Stanton] #764973
08/05/10 12:36 AM
08/05/10 12:36 AM
Az
Crizila Offline
Crizila  Offline
Az
Been a while, but try www.tptools.com.
Fastest 300
