Re: What's are your ideas for a street car?
[Re: Dragula]
#764673
08/04/10 11:15 AM
08/04/10 11:15 AM
Posts: 6,295 U.S.
moparniac
U.S.
I agree with chip!!! Keep your ride... Part out the top end and a cam change... Should give you enough cash to set your ride up for pro touring deal...
Mopar Performance
[Re: Dragula]
#764674
08/04/10 12:05 PM
08/04/10 12:05 PM
Posts: 4,573 ...gently down the stream
LAR_414
My setup is a stock 833 trans out of an E-body. McLeod Dual Disc RST clutch. Stock pedals, Hurst Super shifter III, Dana 60, ET Street (bias ply) tires at the track.
In order to eliminate some human error and be more consistent, I installed a roller switch on my clutch pedal. Very easy to wire up a cool two step rpm limiter. I push the clutch in, push one (momentary) button, and that "sets" the two step rpm limit. It won't come off that until the clutch is all the way out (launching). Then the relay goes to normal (no more two step) for all other shifts. Pretty cool. So it leave at the same rpm every run. No more finger co=ordination with the foot!
Seems very consistent, as I ran two runs with the same launch setup, and the 60' times were almost exact!
My dad and I both have our cars setup to spin the tires (limited) on the launch, to keep the rpms up and not break stuff. Clutch is locked 100% and doesn't slip at all.
If we get the tires to spin about 2 -3 revs (look at the video camera after a pass), that seems about right. I'm pulling the wheels and spinning the tires on the launch....kinda "early pro-stock like". Works great. Got to use Bias ply tires, because drag radials don't like to recover consistently, once they start spinning.
I power shift all the gear changes and that's with a 100% stock trans! No proshifting, no faceplates,.... Stock 23 spline. Can drive it on the street 100% normal, like the day it came from Detroit.
I'm loving it!
[Re: LAR_414]
#764675
08/04/10 12:44 PM
08/04/10 12:44 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
I'm loving it!
Larry what rpm are you shifting at...????
Rickster
[Re: rickstershemi]
#764676
08/04/10 01:26 PM
08/04/10 01:26 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I have been helping my friends drop LS motors in there old cars.
buy a cheap intake and throw a carb on with a MSD box that runs the ignition. that is where its at!! these new Hemi motors need to drop in price a little and we will be able to do the same thing.
i have a friend i helped slap a turbo on a basically stock LS motor. he has like no money in this setup and runs about what i run. so it has to be making over 700hp. and he has never put race gas in the car either.
the tall valve covers and mod man intake that Indy makes for the Hemi look period correct with a modern twist.
I cant wait for prices to come down on these junk yard hemi engines
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#764677
08/04/10 01:46 PM
08/04/10 01:46 PM
Posts: 10,046 MN
JERICOGTX
MN
Bob, keep what you have... Just like Chip, I'm NOT a big fan of the new Challengers... Detune, the Dat, make it more user friendly in the interior department, and drive it. Hey I have 2 STREET cars sitting in my garage right now, and neither one has been outside since my Dad and brother brought them here to store them... Neither one has the time to come take them out , so it's not just a race car thing. Other commitments will be there just like now.
Jeff
69 GTX
68 Road Runner
[Re: ProSport]
#764680
08/04/10 02:32 PM
08/04/10 02:32 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
I've driven 12 second stick shift cars and in my opinion they are not as fun as a 9 second auto.
Maybe......but I haven't lost interest in my car.
[Re: dustergirl340]
#764682
08/04/10 03:12 PM
08/04/10 03:12 PM
Posts: 13,387 Marion, South Carolina [><]
an8sec70cuda
LOL, nice.
[Re: ProSport]
#764683
08/04/10 05:21 PM
08/04/10 05:21 PM
Posts: 2,578 sweden
1Fast340
sweden
i think whipple may have something in the works for the new generation hemi, for a LA smallblock i have only found two options and i have thought about a third 1: indy modman intake for LA or magnum motors with a just a adaptor plate. 2: custom built for real low profile (alot more money 2000$ and up for just a manifold) 3: this is something i havent looked deeper into but it may be possible to use a smallblock chevy intake with adaptorplates and some machinework since it looks like a smallblockmopar intake is alitle wider compared to a SBC but i dont have this confirmed but the port layout is fairly close twinscrews can be fairly easy to hide under a low scoop and will make stupid boost only drawback is the cost and they have a whine all of there own
[Re: Runner]
#764686
08/04/10 07:22 PM
08/04/10 07:22 PM
I'd like to do up an early A-body sedan with a modern 5.7 Hemi and 5 speed.
For now I'm happy with my '63 330 that's going together with very mild 440, 3.55's and sure-grip in the rear.
Last car I did like this got decent mileage (14-15mpg@70mph) on the highway and was very pleasant to drive around town.
[Re: Quicktree]
#764691
08/04/10 10:31 PM
08/04/10 10:31 PM
Posts: 719 Ohio
Dodgetony
mopar addict
mopar addict
Ohio
a new challenger with cold a/c
That's the route I went when I sold my Demon. I do not regret it one bit!!
