'00 Chrysler Sebring turn signal issue
#763539
08/02/10 03:17 PM
08/02/10 03:17 PM
Posts: 1,663 South Lyon, MI.48178
kwhmopar1
Hello, my brother-in-law has a 2000 Chrysler Sebring conv. He is having an issue where the turn signal only blinks a couple times then stops blinking. The lever does not move, just the lamps stop blinking. He was thinking the signal switch in the steering column. I have not looked at the car yet, though I am not sure what to look for. I know on some of the newer models, the turn signal is not like it used to be on the old cars with a simple flasher unit. I know on my '03 Ram, the indicator in the dash doesn't blink at the same frquency as the outside lamps, like they are 2 separate systems. If anyone has any insight I'd appreciate any advice on this problem. Thanks in advance, Kevin
Junk is something you throw away just before you need it.
Re: '00 Chrysler Sebring turn signal issue
[Re: buildanother]
#763541
08/03/10 06:31 AM
08/03/10 06:31 AM
kwhmopar1
Thanks for the reply. I'll have him look into that. I did not realize they still had an actual flasher unit/relay.
