'00 Chrysler Sebring turn signal issue #763539
08/02/10 03:17 PM
08/02/10 03:17 PM
South Lyon, MI.48178
K
kwhmopar1 Offline OP
K
Hello, my brother-in-law has a 2000 Chrysler Sebring conv. He is having an issue where the turn signal only blinks a couple times then stops blinking. The lever does not move, just the lamps stop blinking. He was thinking the signal switch in the steering column. I have not looked at the car yet, though I am not sure what to look for. I know on some of the newer models, the turn signal is not like it used to be on the old cars with a simple flasher unit. I know on my '03 Ram, the indicator in the dash doesn't blink at the same frquency as the outside lamps, like they are 2 separate systems. If anyone has any insight I'd appreciate any advice on this problem. Thanks in advance, Kevin
Junk is something you throw away just before you need it.
Re: '00 Chrysler Sebring turn signal issue [Re: kwhmopar1] #763540
08/02/10 07:21 PM
08/02/10 07:21 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I can only tell you my 2000 dakota was doing a similar thing and did need a new flasher. It was a separate piece, looked like a little hella type black square relay.
Re: '00 Chrysler Sebring turn signal issue [Re: buildanother] #763541
08/03/10 06:31 AM
08/03/10 06:31 AM
K
K
Thanks for the reply. I'll have him look into that. I did not realize they still had an actual flasher unit/relay.
Re: '00 Chrysler Sebring turn signal issue [Re: kwhmopar1] #763542
08/03/10 10:21 AM
08/03/10 10:21 AM
chicagoland,usa
chicagoland,usa
Maybe the sebring does not. I don't know.
Re: '00 Chrysler Sebring turn signal issue [Re: kwhmopar1] #763543
08/03/10 12:15 PM
08/03/10 12:15 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
The Flasher, (Combo flasher) is on the multifunction switch, remove the steering column covers and it sticks out the front of the switch slightly to the right...It will look like your typical Bosch ISO relay except twice the length.
Rick
Re: '00 Chrysler Sebring turn signal issue [Re: Blown71X] #763544
08/04/10 06:10 AM
08/04/10 06:10 AM
K
K
Re: '00 Chrysler Sebring turn signal issue [Re: kwhmopar1] #763545
08/04/10 10:50 AM
08/04/10 10:50 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
On a different note.....I strongly recommend that you get one from a dealer even if it costs more, I have had extremely poor luck with aftermarket ones and won`t even try them anymore.
Rick
