Re: A-body SS Spring 3" re-location kit?? - Help??
[Re: wkroncke17]
#75941
06/19/08 04:49 PM
06/19/08 04:49 PM
[Re: wkroncke17]
#75942
06/20/08 01:30 AM
06/20/08 01:30 AM
Posts: 636 California
sixpaktoogo
California
I think there may have just been a post on here,but I can't find it. I'm putting on the kit to move the springs 3" inboard on my '72 Demon. I have the springs,and kit,is there anything else I need to purchase and install along with this kit? Any tips or advice that I need before I start to do this? Again,any help is really appreciated guys! Thanks in advance!! Thanks Moparts!!
To use the 3 inches you gain by moving the spring onto the frame rail, you will also need to mini-tub your inner wheel well 3 inches. That will put it flush with the frame rail. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: sixpaktoogo]
#75945
06/20/08 02:03 PM
06/20/08 02:03 PM
Posts: 199 douglasville,ga
ramrod
douglasville,ga
Unless they've changed it, the hole in the new spring perches for the leaf spring clamp bolt is too big on the Mopar Performance kit. You may have to fab a bushing if you use the MP kit.
"That Plymouth had a Hemi with a Torqueflite."
-Driver
[Re: wkroncke17]
#75947
06/20/08 05:47 PM
06/20/08 05:47 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
Only advice I would give you is to drill 2 or 3 holes in the boxes before you weld them in. That way you have the option to lower/raise the height of the car, or even move the rear back a little if you'd like to run a taller tire. I just ended up drilling a new set of holes in the boxes a couple of days ago to move my rear back an inch for taller meats. Would have been SO MUCH easier to do it before I had the boxes welded in. Live and learn. And minitubbing isn't that hard to do. And can be made to look factory if you take your time with it. codfish ![](/ubbthreads/images/graemlins/beer.gif)
[Re: ramrod]
#75949
06/20/08 08:04 PM
06/20/08 08:04 PM
Posts: 8,147 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
The MP kit spring perches have a large locating hole for the leaf spring. Morroso makes ones with a better locator hole. I got mine from Summit.
[Re: UCUDANT]
#75950
06/20/08 09:20 PM
06/20/08 09:20 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
If you're doing a relocation kit, you have to have a welder. No?
Get a piece of pipe that is 3/4" od and 1/2" id and weld it in the too big hole like a sleeve. No biggie, done two sets like that in the last 2 months. 20 minutes tops.
