Need mopar part# for bronze dist. shaft/gear unit. #756106
07/23/10 08:17 PM
07/23/10 08:17 PM
State of confusion
Thumperdart Offline OP
State of confusion
I`m in need of the part # for the direct connection/mopar perf. dist gear/shaft and can`t find it in my older books and the dealer only has the new books w/out any #`s.............anyone have the #? I run the hv pump.......thankxxx
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: Thumperdart] #756107
07/23/10 08:33 PM
07/23/10 08:33 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
No, but I believe I have one hanging on the wall.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: BloFish] #756108
07/23/10 08:35 PM
07/23/10 08:35 PM
State of confusion
State of confusion
Is it the right one and is it new or used?
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: Thumperdart] #756109
07/23/10 08:39 PM
07/23/10 08:39 PM
On the run…
On the run…
I bought it N.O.S. for my big block. Will that work for you?
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: BloFish] #756110
07/23/10 08:42 PM
07/23/10 08:42 PM
State of confusion
State of confusion
I`m not sure but when I changed mine over 3 years ago, I got it from the local dealer and I assume it`s correct seeing that I`ve got lots of miles on this thing.
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: Thumperdart] #756111
07/23/10 09:40 PM
07/23/10 09:40 PM
Chattanooga,Tn
Mopar Racer Offline
Mopar Racer  Offline
Chattanooga,Tn
The part# is P1737725
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: Mopar Racer] #756112
07/23/10 09:41 PM
07/23/10 09:41 PM
State of confusion
State of confusion
Thankxx...........
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: Mopar Racer] #756113
07/23/10 10:26 PM
07/23/10 10:26 PM
Delray beach, Florida
P
Performance Only Offline
P
i'm pretty sure that part # is for the intermediate shaft bushing.
a bronze gear and shaft is P3690875 and the cast iron gear is P3571071
machine shop owner and engine builder
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: Performance Only] #756114
07/23/10 10:34 PM
07/23/10 10:34 PM
State of confusion
State of confusion
Now I`m confused...I`ll shoot the #`s to the dealer tomorrow and see what they come up w/if Blowfish doesn`t have what I need.
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: Thumperdart] #756115
07/23/10 10:48 PM
07/23/10 10:48 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: Thumperdart] #756116
07/23/10 10:48 PM
07/23/10 10:48 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
this is what my last catalog shows also
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: dusturbd340W5] #756117
07/23/10 10:55 PM
07/23/10 10:55 PM
State of confusion
State of confusion
Thankxx guys...........
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: dusturbd340W5] #756118
07/23/10 10:58 PM
07/23/10 10:58 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Summit says it ships Monday.
I bought mine on line from a dealer and got spanked price wise...........one in S.C.
I ordered a bunch of R-3 and W-9 stuff since they appeared to have it in stock.
This was the only part they had in stock and they were plenty proud of it.
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: tubtar] #756119
07/23/10 11:12 PM
07/23/10 11:12 PM
P
P
if you ordered the smallblock bronze gear they're over 200.00 bucks now.
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: tubtar] #756120
07/23/10 11:39 PM
07/23/10 11:39 PM
State of confusion
State of confusion
I share an account at the dealer here locally so I`ll see how much $$$ tomorrow.
Re: Need mopar part# for bronze dist. shaft/gear unit. [Re: Performance Only] #756121
07/24/10 10:31 AM
07/24/10 10:31 AM
NC
440Jim Offline
440Jim  Offline
NC
Confirmed, P1737725 is the bushing.
Bronze gear oil pump drive P3690875, and the cast gear number is correct too for normal oil pump length (std or HV, internal pickup).
According to Andy's book there are 3 different shafts, the
factory replacement pump uses a 6.40" shaft,
the high volume alum pump from Milodon uses a 6.60" shaft,
the 7.0" shaft is used for oil pump systems where a spacer plate
is used for a second inlet system.....
this is measured from the bottom of the gear to the tip.
I measured 6-3/8" on an old stock one.
