Need mopar part# for bronze dist. shaft/gear unit.
#756106
07/23/10 08:17 PM
07/23/10 08:17 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I`m in need of the part # for the direct connection/mopar perf. dist gear/shaft and can`t find it in my older books and the dealer only has the new books w/out any #`s.............anyone have the #? I run the hv pump.......thankxxx
Re: Need mopar part# for bronze dist. shaft/gear unit.
[Re: Thumperdart]
#756107
07/23/10 08:33 PM
07/23/10 08:33 PM
Posts: 16,483 On the run…
BloFish
On the run…
No, but I believe I have one hanging on the wall.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#756108
07/23/10 08:35 PM
07/23/10 08:35 PM
Thumperdart
State of confusion
Is it the right one and is it new or used?
[Re: Thumperdart]
#756109
07/23/10 08:39 PM
07/23/10 08:39 PM
BloFish
On the run…
I bought it N.O.S. for my big block. Will that work for you?
[Re: Mopar Racer]
#756113
07/23/10 10:26 PM
07/23/10 10:26 PM
Posts: 2,091 Delray beach, Florida
Performance Only
The part# is P1737725
i'm pretty sure that part # is for the intermediate shaft bushing.
a bronze gear and shaft is P3690875 and the cast iron gear is P3571071
machine shop owner and engine builder
[Re: Thumperdart]
#756116
07/23/10 10:48 PM
07/23/10 10:48 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
this is what my last catalog shows also
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#756118
07/23/10 10:58 PM
07/23/10 10:58 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Summit says it ships Monday. I bought mine on line from a dealer and got spanked price wise...........one in S.C. I ordered a bunch of R-3 and W-9 stuff since they appeared to have it in stock. This was the only part they had in stock and they were plenty proud of it.
[Re: Performance Only]
#756121
07/24/10 10:31 AM
07/24/10 10:31 AM
Posts: 16,928 NC
440Jim
NC
Confirmed, P1737725 is the bushing. Bronze gear oil pump drive P3690875, and the cast gear number is correct too for normal oil pump length (std or HV, internal pickup).
According to Andy's book there are 3 different shafts, the factory replacement pump uses a 6.40" shaft, the high volume alum pump from Milodon uses a 6.60" shaft, the 7.0" shaft is used for oil pump systems where a spacer plate is used for a second inlet system..... this is measured from the bottom of the gear to the tip.
I measured 6-3/8" on an old stock one.
