TIRE Clearance / Backspacing / Question... Help
#752592
07/19/10 04:38 PM
07/19/10 04:38 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
What is a "safe" distance between the inside of the tire and outside of the frame rail ? I need to "move" my tires IN,,,they are too close to the lip of the quarter panel.....and the tire is rubbing/hitting the lip of the quarter panel I should be able to do this with changing the backspacing on the rims,,,,, Right now,,,I have a Weld Prostar 12 x 15 rim,,,with 6.5" of backspacing.... Right now,,I have 2" of "room" between the inside of the tire,,,to the outside of the frame....(see pic") If i was to change to 7.5" of backspacing,,,that would leave me 1" on the inside of the tire to frame....is that ok...too close ... just right....?? Trying to avoid shortening the rear end to gain the clearance ![](http://i212.photobucket.com/albums/cc79/69CHARGERMD/P7190001.jpg)
Re: TIRE Clearance / Backspacing / Question... Help
[Re: 69CHARGERMD]
#752593
07/19/10 04:44 PM
07/19/10 04:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Doug... I would give it 1".... but if you dont have any spacers behind the wheel its going to be NEW rim time to correct it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#752594
07/19/10 04:51 PM
07/19/10 04:51 PM
69CHARGERMD
KENTUCKY
Mike, I was going to get 2 new rims,,,12 x 15,,,but get 7.5" backspacing.......
does this sound like it would work ?
this should move everything IN 1",,,and give me the outside clearance i need.....
[Re: 69CHARGERMD]
#752596
07/19/10 06:13 PM
07/19/10 06:13 PM
MR_P_BODY
Mike, I was going to get 2 new rims,,,10 x 15,,,but get 7.5" back spacing.......
Sounds good to me but do they make a 7.5 BS wheel ![](/ubbthreads/images/graemlins/wave.gif)
[Re: firefighter3931]
#752599
07/19/10 06:32 PM
07/19/10 06:32 PM
you can always get a mr.gasket wheel spacer up to 1/4" to bring it out a little. sounds to me you got the same axle width as me. thats what i do, wheel spacers are your friend.
[Re: 69CHARGERMD]
#752601
07/19/10 06:37 PM
07/19/10 06:37 PM
This is what i ordered from Harlow.....
http://www.summitracing.com/parts/WLD-96-512214/
I thought i had a 10" rim,,,but it's actually 12"
thats what i run.stock spacing dana you'll probably need a wheel spacer.
#752602
07/19/10 06:39 PM
07/19/10 06:39 PM
69CHARGERMD
KENTUCKY
Why a wheel spacer... ? I measured what i have now,,,and it looks like it should fit with 1" of clearance at the inside of the tire to the frame,,,,and about 3/4-1" at the quarter panel.... Was your clearance less than 1" on the inside portion of the tire ? thanks, Doug ps,,,i think,,,but am not sure,,,but the current Dana may have been modified prior to going in the car,,,so i might not be "stock" spacing...i would have to ask the previous owner where the Dana came from,,and if it was modified any before the initial install. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: nss guy]
#752607
07/19/10 09:20 PM
07/19/10 09:20 PM
69CHARGERMD
KENTUCKY
Jim, I have a 31 x 10.5 x 15W tire, Current rim is a 12 x 15 with 6.5 BS Not sure if my Dana is "stock" width,,or if it's been modified previously (length wise) Caltracs If i measured correctly,,,,just changing my backspacing to 7.5" should get me the room i need.... Tom, that's going to leave a mark,,ouch,,lol I wasnt breaking stuff then like i am now,,, ![](/ubbthreads/images/graemlins/runaway.gif)
[Re: 69CHARGERMD]
#752608
07/19/10 10:15 PM
07/19/10 10:15 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
thanks,
Hi Doug sorry to hear you are having problems.I still think the leaf springs are tired. but to answer your questions. the dana i got from my uncle which came out of a 78 3/4 ton ford truck.he already had it cut down pretty good.there was enough length left to make it the same length as the 8-3/4 that cam out of the car. Doug have you measured the rims yet? because i thought they are already 15x10 with 7.5 inches of back spacing. but it has been so long ago i don't remember. I know a M/T 29.5x11.5x15 will fit the car perfect if you wanted to go that route. sorry if i am not much help.Bobby
doug here is a pic of the car when i had the 29.5 slicks on it. Doug
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#752609
07/19/10 10:17 PM
07/19/10 10:17 PM
mopar65
sorry for got to say that moser put the housing ends on the rear end for me.thanks Bobby
support our troops
