TIRE Clearance / Backspacing / Question... Help #752592
07/19/10 04:38 PM
07/19/10 04:38 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
What is a "safe" distance between the inside of the tire and outside of the frame rail ?
I need to "move" my tires IN,,,they are too close to the lip of the quarter panel.....and the tire is rubbing/hitting the lip of the quarter panel
I should be able to do this with changing the backspacing on the rims,,,,,
Right now,,,I have a Weld Prostar 12 x 15 rim,,,with 6.5" of backspacing....
Right now,,I have 2" of "room" between the inside of the tire,,,to the outside of the frame....(see pic")
If i was to change to 7.5" of backspacing,,,that would leave me 1" on the inside of the tire to frame....is that ok...too close ... just right....??
Trying to avoid shortening the rear end to gain the clearance
Re: TIRE Clearance / Backspacing / Question... Help [Re: 69CHARGERMD] #752593
07/19/10 04:44 PM
07/19/10 04:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug... I would give it 1".... but if you dont have
any spacers behind the wheel its going to be NEW rim
time to correct it
Re: TIRE Clearance / Backspacing / Question... Help [Re: MR_P_BODY] #752594
07/19/10 04:51 PM
07/19/10 04:51 PM
KENTUCKY
KENTUCKY
Mike,
I was going to get 2 new rims,,,12 x 15,,,but get 7.5" backspacing.......
does this sound like it would work ?
this should move everything IN 1",,,and give me the outside clearance i need.....
Re: TIRE Clearance / Backspacing / Question... Help [Re: MR_P_BODY] #752595
07/19/10 04:52 PM
07/19/10 04:52 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
1" is plenty.....remember tires get narrower at speed.....the 1" is more for body roll and cornering when turning off the track....thats when the major shift occurs.
Re: TIRE Clearance / Backspacing / Question... Help [Re: 69CHARGERMD] #752596
07/19/10 06:13 PM
07/19/10 06:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike,
I was going to get 2 new rims,,,10 x 15,,,but get 7.5" back spacing.......
Sounds good to me but do they make a 7.5 BS wheel
Re: TIRE Clearance / Backspacing / Question... Help [Re: 69CHARGERMD] #752597
07/19/10 06:19 PM
07/19/10 06:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I drive my heap all over w/about a 1/2" clearance everywhere and SOMETIMES it rubs on the inside of the tub but it`s liveable. I wish I had 1" but I run a 12" wheel and want the biggest footprint I can get so,
Re: TIRE Clearance / Backspacing / Question... Help [Re: MR_P_BODY] #752598
07/19/10 06:25 PM
07/19/10 06:25 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Mike,
Sure do
http://www.summitracing.com/parts/WLD-96510214/
Ron
Re: TIRE Clearance / Backspacing / Question... Help [Re: firefighter3931] #752599
07/19/10 06:32 PM
07/19/10 06:32 PM
you can always get a mr.gasket wheel spacer up to 1/4" to bring it out a little. sounds to me you got the same axle width as me.
thats what i do, wheel spacers are your friend.
Re: TIRE Clearance / Backspacing / Question... Help [Re: firefighter3931] #752600
07/19/10 06:33 PM
07/19/10 06:33 PM
KENTUCKY
KENTUCKY
This is what i ordered from Harlow.....
http://www.summitracing.com/parts/WLD-96-512214/
I thought i had a 10" rim,,,but it's actually 12"
Re: TIRE Clearance / Backspacing / Question... Help [Re: 69CHARGERMD] #752601
07/19/10 06:37 PM
07/19/10 06:37 PM
thats what i run.stock spacing dana you'll probably need a wheel spacer.
Re: TIRE Clearance / Backspacing / Question... Help #752602
07/19/10 06:39 PM
07/19/10 06:39 PM
KENTUCKY
KENTUCKY
Why a wheel spacer... ?
I measured what i have now,,,and it looks like it should fit with 1" of clearance at the inside of the tire to the frame,,,,and about 3/4-1" at the quarter panel....
Was your clearance less than 1" on the inside portion of the tire ?
thanks,
Doug
ps,,,i think,,,but am not sure,,,but the current Dana may have been modified prior to going in the car,,,so i might not be "stock" spacing...i would have to ask the previous owner where the Dana came from,,and if it was modified any before the initial install.
Re: TIRE Clearance / Backspacing / Question... Help #752603
07/19/10 08:14 PM
07/19/10 08:14 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When I had 29 x 10.5 Hoosiers I had about 1/2" clearence on the inside and outside in my stock wheelwells. It was ok going straight but driving around it rubbed to much. When my buddy said I had smoke coming out of my wheelwell on the highway ramp I figured I need to change it. Now I have 30 x 9 Hoosiers and they have about 1-1/2" of room and never rub. Ron
Re: TIRE Clearance / Backspacing / Question... Help [Re: 69CHARGERMD] #752604
07/19/10 08:52 PM
07/19/10 08:52 PM
Dana Point, CA
Fast Yeti Offline
Fast Yeti  Offline
Dana Point, CA
Doug, isn't that the exact same wheel and back spacing I tried to sell you a couple of years ago from my Roadrunner?
Re: TIRE Clearance / Backspacing / Question... Help [Re: 69CHARGERMD] #752605
07/19/10 09:16 PM
07/19/10 09:16 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Doug,
What size tires are you running? I have a 'stock width' dana and run 15 x 10 rims with 6.5 backspacing. My spring s are moved in and this seems to be the best fit with 29.5 x 10.5 slicks or 30 x 9 radials.
Re: TIRE Clearance / Backspacing / Question... Help [Re: nss guy] #752606
07/19/10 09:19 PM
07/19/10 09:19 PM
Lehigh Acres, Florida
rickstershemi Offline
Mine on the pickup are 3/4" and never rub even under hard conering and that is with only 25lbs of pressure
Rickster
Re: TIRE Clearance / Backspacing / Question... Help [Re: nss guy] #752607
07/19/10 09:20 PM
07/19/10 09:20 PM
KENTUCKY
KENTUCKY
Jim,
I have a 31 x 10.5 x 15W tire,
Current rim is a 12 x 15 with 6.5 BS
Not sure if my Dana is "stock" width,,or if it's been modified previously (length wise)
Caltracs
If i measured correctly,,,,just changing my backspacing to 7.5" should get me the room i need....
Tom,
that's going to leave a mark,,ouch,,lol
I wasnt breaking stuff then like i am now,,,
Re: TIRE Clearance / Backspacing / Question... Help [Re: 69CHARGERMD] #752608
07/19/10 10:15 PM
07/19/10 10:15 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
thanks,
Hi Doug sorry to hear you are having problems.I still think the leaf springs are tired. but to answer your questions. the dana i got from my uncle which came out of a 78 3/4 ton ford truck.he already had it cut down pretty good.there was enough length left to make it the same length as the 8-3/4 that cam out of the car. Doug have you measured the rims yet? because i thought they are already 15x10 with 7.5 inches of back spacing. but it has been so long ago i don't remember. I know a M/T 29.5x11.5x15 will fit the car perfect if you wanted to go that route. sorry if i am not much help.Bobby
doug here is a pic of the car when i had the 29.5 slicks on it.
Doug
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: TIRE Clearance / Backspacing / Question... Help [Re: mopar65] #752609
07/19/10 10:17 PM
07/19/10 10:17 PM
mopar65 Offline
mopar65  Offline
sorry for got to say that moser put the housing ends on the rear end for me.thanks Bobby
Re: TIRE Clearance / Backspacing / Question... Help [Re: mopar65] #752610
07/20/10 12:11 AM
07/20/10 12:11 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
So you have a 12x15 now and you want to
replace it with a 10x15?
Why? just buy the same width rim with 1"
more b.s.
Re: TIRE Clearance / Backspacing / Question... Help [Re: demon440] #752611
07/20/10 12:29 AM
07/20/10 12:29 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
i have 10x15 w 7 1/2 bs brand new weld draglites and i could use a 6 1/2 bs
