Hydraulic clutch linkage for A-833? #750955
07/17/10 11:55 PM
07/17/10 11:55 PM
southern Idaho
moparcyco Offline OP
southern Idaho
Hello all was just wondering if something like this exists?I am going to get a passon overdrive kit for my super bee.I can probably fabricate something up but would be easier if I had something to start with.Anybody out there in moparland ever attemted this or better yet have a working setup in your car?I would just like to try while I have the car apart to see if it is any better than the factory setup.Thanks guys
Re: Hydraulic clutch linkage for A-833? [Re: moparcyco] #750956
07/18/10 12:05 AM
07/18/10 12:05 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You could contact Keisler to inquire/purchase their Keisler/Wilwood modified master and FTE hyd. throw out bearing, best to know what installed "stack" height of the TOB you may require?......easy mod to perform, basic fabrication
Re: Hydraulic clutch linkage for A-833? [Re: DAYCLONA] #750957
07/18/10 12:25 AM
07/18/10 12:25 AM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
a couple threads from another site:
http://www.forabodiesonly.com/mopar/showthread.php?t=33640
http://www.forabodiesonly.com/mopar/showthread.php?t=40229
this is the package i'm going to use:
http://www.chucksclassiccars.com/index.php?item=HYDC833
it was recommended by an aussie that has it installed on his oz charger. i like it because of the slave cyl. mounting plate that can pivot during use so theres no binding.
i haven't heard anything good about hydraulic actuated throw out bearings because of accessability when installed, you might want to research what would be best for your application i.e. street use or track.
Re: Hydraulic clutch linkage for A-833? [Re: pauly v.100] #750958
07/18/10 12:38 AM
07/18/10 12:38 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Send goldduster318 a PM. He built his own system using wilwood parts from summit. He gave me the part #'s for all the stuff he used and I bought those same components from summit. I haven't installed it yet but it basically uses a hydraulic master cyl to actuate a slave cylinder which in turn operates your clutch fork. No $$ hydraulic throw out bearing in this setup.
Re: Hydraulic clutch linkage for A-833? [Re: DaytonaTurbo] #750959
07/18/10 12:44 AM
07/18/10 12:44 AM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
It can be done with stock parts. Late 80s 2wd trucks with slant 6 engines and 4 speeds had hydraulic clutches, and they were A833 trannies. Replacement parts can be found through your local parts store as needed.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Hydraulic clutch linkage for A-833? [Re: maundmotorworks] #750960
07/18/10 12:51 AM
07/18/10 12:51 AM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
The one caveat that all hydraulic conversions seem to have in common is that your firewall has to be reinforced where the clutch master cyl. mounts else it will flex badly and maybe even eventually fail.
Re: Hydraulic clutch linkage for A-833? [Re: pauly v.100] #750961
07/18/10 12:58 AM
07/18/10 12:58 AM
Manitoba, Canada
Manitoba, Canada
Yes definitely, I would not bolt it to a thin piece of firewall sheetmetal.
Re: Hydraulic clutch linkage for A-833? [Re: DaytonaTurbo] #750962
07/18/10 01:20 AM
07/18/10 01:20 AM
southern Idaho
southern Idaho
Thanks guys I happen to work at a parts house so hopefully I can get this stuff at a slight discount.I like the 2wd truck idea.I will definetly pm gold duster318 as well.Any other suggestion keep them coming.
Also whats the best way to reinforce the firewall?
Re: Hydraulic clutch linkage for A-833? [Re: moparcyco] #750963
07/18/10 01:55 AM
07/18/10 01:55 AM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
anything to distribute the load from the master cyl. flange. simple 1/8 steel plate welded around the area will do. inside or out. just remember to factor in that difference for the clutch/master pushrod.
haven't done this yet, i'm just weighing in on the research i've done and the knowledge i've gleened from boning up on the subject.
i'm still waiting on the rest of the parts needed
for my auto/4speed conversion.
imo, the kit from chucks is the way to go
