Re: Hydraulic clutch linkage for A-833?
[Re: DaytonaTurbo]
#750959
07/18/10 12:44 AM
07/18/10 12:44 AM
Posts: 1,209 Fredericktown, PA 15333
maundmotorworks
Stealth poster
Stealth poster
It can be done with stock parts. Late 80s 2wd trucks with slant 6 engines and 4 speeds had hydraulic clutches, and they were A833 trannies. Replacement parts can be found through your local parts store as needed.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
[Re: pauly v.100]
#750961
07/18/10 12:58 AM
07/18/10 12:58 AM
DaytonaTurbo
Manitoba, Canada
The one caveat that all hydraulic conversions seem to have in common is that your firewall has to be reinforced where the clutch master cyl. mounts else it will flex badly and maybe even eventually fail.
Yes definitely, I would not bolt it to a thin piece of firewall sheetmetal.
