a couple threads from another site:
http://www.forabodiesonly.com/mopar/showthread.php?t=33640http://www.forabodiesonly.com/mopar/showthread.php?t=40229this is the package i'm going to use:
http://www.chucksclassiccars.com/index.php?item=HYDC833it was recommended by an aussie that has it installed on his oz charger. i like it because of the slave cyl. mounting plate that can pivot during use so theres no binding.
i haven't heard anything good about hydraulic actuated throw out bearings because of accessability when installed, you might want to research what would be best for your application i.e. street use or track.
