Oil Filter relocation #748612
07/14/10 10:38 PM
07/14/10 10:38 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
I have made up a kit to relocate the Oil filter for Small Block Chryslers. I currently offer the kit with -10AN fittings and am wondering if I should offer it with -8AN fittings.
My main apprehension is the ID of the -8AN fittings is around 0.100" smaller than the -10AN and the original fitting. Is the smaller fitting going to provide a detrimental restiction for a mild engine?
Thoughts? Comments?
Alan Jones
Re: Oil Filter relocation [Re: LA360] #748613
07/14/10 10:40 PM
07/14/10 10:40 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
I have NO clue but it looks GREAT!!!!!
Re: Oil Filter relocation [Re: LA360] #748614
07/14/10 10:54 PM
07/14/10 10:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thoughts? Comments?
I would think that the -8 would be more in line with
the supply size right before the plate.... but the
-10 will always work... good looking part
Re: Oil Filter relocation [Re: LA360] #748615
07/15/10 01:39 AM
07/15/10 01:39 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
when i modified my Milodon external kit & removed the filter adaptor & fitted -10 remote lines to a Fram HP6 filter i saw a 5 psi drop. i thought I had gone -12 i might have reduced the possibility of the pressure drop. if it was me, i wouldn't use anything less than -10. oil when cold don't like 90* or more bends so keep it big.
Re: Oil Filter relocation [Re: rebel] #748616
07/15/10 01:47 AM
07/15/10 01:47 AM
LA360 Offline OP
LA360  Offline OP
On a performance engine, I wouldn't personally use anything less that -10, I have been asked for -8 though. I might make a few fittings and see how they go.
Alan Jones
Re: Oil Filter relocation [Re: LA360] #748617
07/15/10 01:59 AM
07/15/10 01:59 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
in Australia they did a remote filter for the 318 since it interfered with the RH drive steering box. i just checked a set of hardline pipes for one of these & it's the same as my -10 fitting internal size. so the factory went -10 too & that was old the 2bbl motor. i'd stay with the larger size dude.
Re: Oil Filter relocation [Re: LA360] #748618
07/15/10 03:27 PM
07/15/10 03:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I would think the length of the hoses has a lot to do with selecting hose size; for example, 30" of #10 versus 15" of #8.
Re: Oil Filter relocation [Re: LA360] #748619
07/15/10 06:11 PM
07/15/10 06:11 PM
Lehigh Acres, Florida
rickstershemi Offline
Wish you were here in the states, I'd order one in a heartbeat
Does it use an o-ring or gasket...?????
Rickster
Re: Oil Filter relocation [Re: LA360] #748620
07/15/10 07:26 PM
07/15/10 07:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was thinking(scary) the pick up tube is 3/8 pipe
which is 3/8 ID and you had a -10 which is 5/8 ID
-8 is 1/2 ID so either should be fine(the first restriction
in line is the one controlling the flow) Ok I'm
going back to sleep
EDIT
and thats the suction side which is normally larger
