Oil Filter relocation
#748612
07/14/10 10:38 PM
07/14/10 10:38 PM
Posts: 6,145 Melbourne , Australia
LA360
I have made up a kit to relocate the Oil filter for Small Block Chryslers. I currently offer the kit with -10AN fittings and am wondering if I should offer it with -8AN fittings. My main apprehension is the ID of the -8AN fittings is around 0.100" smaller than the -10AN and the original fitting. Is the smaller fitting going to provide a detrimental restiction for a mild engine? Thoughts? Comments?
Alan Jones
Re: Oil Filter relocation
[Re: LA360]
#748614
07/14/10 10:54 PM
07/14/10 10:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thoughts? Comments?
I would think that the -8 would be more in line with the supply size right before the plate.... but the -10 will always work... good looking part
[Re: rebel]
#748616
07/15/10 01:47 AM
07/15/10 01:47 AM
LA360
On a performance engine, I wouldn't personally use anything less that -10, I have been asked for -8 though. I might make a few fittings and see how they go.
Alan Jones
[Re: LA360]
#748620
07/15/10 07:26 PM
07/15/10 07:26 PM
MR_P_BODY
I was thinking(scary) the pick up tube is 3/8 pipe which is 3/8 ID and you had a -10 which is 5/8 ID -8 is 1/2 ID so either should be fine(the first restriction in line is the one controlling the flow) Ok I'm going back to sleep EDIT and thats the suction side which is normally larger
