Re: 383man
[Re: GregCon]
#747778
07/14/10 08:38 AM
07/14/10 08:38 AM
Posts: 679 N.E Indiana
repad
super street
super street
N.E Indiana
I just doubt an intake leak could cause that level of misfire - you'd need a big leak to entirely prevent the cylinder from hitting. And, how would you blow out a metal gasket? Or are you using those thin paper gaskets too?
What else other than the items that I checked could cause the dead cylinder? I'm not using anything but the metal valley pan with unblocked heat crossover and silicone sealant.
Re: Attn engine builders need help troubleshooting 383
[Re: 383'D]
#747779
07/14/10 08:42 AM
07/14/10 08:42 AM
repad
super street
super street
N.E Indiana
Look at the the springs on that cylinder real good for a broken coil.It may look like a hairline crack. Does it smell rich when it runs?Mine ended up being a exhaust spring on #4.Even though almost new.It acted just like that.
I have inspected the springs but will take a closer look. Wouldn't the good compression test rule out a broken spring?
[Re: repad]
#747780
07/14/10 08:43 AM
07/14/10 08:43 AM
Challenger 1
Cincinnati, Ohio
Might be a bad ignition box. I had a brand new MSD box that wouldn't fire #1 and #4.
Sorry, no ignition box, running on points.
It sounds like you need to adjust the dwell. Have you checked that?
Since you said it still back fires sometimes I bet your points are off, what's the dwell?
[Re: Challenger 1]
#747781
07/14/10 08:47 AM
07/14/10 08:47 AM
repad
super street
super street
N.E Indiana
I set the dwell at 29.
[Re: repad]
#747782
07/14/10 08:54 AM
07/14/10 08:54 AM
Posts: 798 Houston TX
GregCon
Houston TX
If there's good spark it doesn't matter what the dwell is.
Does the plug look bone dry or does it look like it is getting washed with some gas?
Again, if you have some gas, air, compression and spark in time it is going to fire. Which is missing?
Just for kick what firing order are you using?
[Re: GregCon]
#747783
07/14/10 09:02 AM
07/14/10 09:02 AM
repad
super street
super street
N.E Indiana
The plug looks very dry with a silght gas odor which tells me that it is not getting a proper shot of fuel. Firing order 18436572
[Re: repad]
#747785
07/14/10 09:36 AM
07/14/10 09:36 AM
Posts: 667 CA
66Dodge
super gas
super gas
CA
1). Check the valve train to see what would cause #3 intake valve to not open properly. (compression good because it stays closed okay, but will not open properly)
2). Just for kicks try a diffrerent dist. cap. (bad contact on terminal #3 could be missing link in spark path)
[Re: 66Dodge]
#747786
07/14/10 10:18 AM
07/14/10 10:18 AM
Posts: 667 CA
66Dodge
super gas
super gas
CA
Okay, we've covered all the basic things that a cylinder needs to fire/combust. Time think outside the box and to look at the weird things that could have happened.
3). Inspect cam lobes in the dist. (worn cam lobe will not close the points all the way, thus no charging of the coil before the points open again)
4). Check for some sort of obstruction in the intake path/runner to cyl.#3. (maybe the ball of aluminum foil was stuffed into intake runner #3 instead of the heat crossover opening ? LOL) (that's why the carb backfired big time ?)
5). Verify you actually saw a spark jump when #3 boot is held close to ground while cranking the engine ?
