Re: 383man [Re: repad] #747776
07/14/10 06:37 AM
07/14/10 06:37 AM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
I just doubt an intake leak could cause that level of misfire - you'd need a big leak to entirely prevent the cylinder from hitting. And, how would you blow out a metal gasket? Or are you using those thin paper gaskets too?
Re: Attn engine builders need help troubleshooting 383 [Re: repad] #747777
07/14/10 07:52 AM
07/14/10 07:52 AM
ogletownpa
3
383'D Offline
383'D  Offline
ogletownpa
Look at the the springs on that cylinder real good for a broken coil.It may look like a hairline crack. Does it smell rich when it runs?Mine ended up being a exhaust spring on #4.Even though almost new.It acted just like that.
Re: 383man [Re: GregCon] #747778
07/14/10 08:38 AM
07/14/10 08:38 AM
N.E Indiana
repad Offline OP
super street
repad  Offline OP
super street
N.E Indiana
What else other than the items that I checked could cause the dead cylinder? I'm not using anything but the metal valley pan with unblocked heat crossover and silicone sealant.
Re: Attn engine builders need help troubleshooting 383 [Re: 383'D] #747779
07/14/10 08:42 AM
07/14/10 08:42 AM
N.E Indiana
repad Offline OP
super street
repad  Offline OP
super street
N.E Indiana
I have inspected the springs but will take a closer look. Wouldn't the good compression test rule out a broken spring?
Re: Attn engine builders need help troubleshooting 383 [Re: repad] #747780
07/14/10 08:43 AM
07/14/10 08:43 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Might be a bad ignition box. I had a brand new MSD box that wouldn't fire #1 and #4.
Sorry, no ignition box, running on points.
It sounds like you need to adjust the dwell. Have you checked that?
Since you said it still back fires sometimes I bet your points are off, what's the dwell?
Re: Attn engine builders need help troubleshooting 383 [Re: Challenger 1] #747781
07/14/10 08:47 AM
07/14/10 08:47 AM
N.E Indiana
repad Offline OP
super street
repad  Offline OP
super street
N.E Indiana
I set the dwell at 29.
Re: Attn engine builders need help troubleshooting 383 [Re: repad] #747782
07/14/10 08:54 AM
07/14/10 08:54 AM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
If there's good spark it doesn't matter what the dwell is.
Does the plug look bone dry or does it look like it is getting washed with some gas?
Again, if you have some gas, air, compression and spark in time it is going to fire. Which is missing?
Just for kick what firing order are you using?
Re: Attn engine builders need help troubleshooting 383 [Re: GregCon] #747783
07/14/10 09:02 AM
07/14/10 09:02 AM
N.E Indiana
repad Offline OP
super street
repad  Offline OP
super street
N.E Indiana
The plug looks very dry with a silght gas odor which tells me that it is not getting a proper shot of fuel. Firing order 18436572
Re: Attn engine builders need help troubleshooting 383 [Re: repad] #747784
07/14/10 09:06 AM
07/14/10 09:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did you check the compression of other cylinders as a comparison ?
Re: Attn engine builders need help troubleshooting 383 [Re: repad] #747785
07/14/10 09:36 AM
07/14/10 09:36 AM
CA
66Dodge Offline
super gas
66Dodge  Offline
super gas
CA
1). Check the valve train to see what would cause #3 intake valve to not open properly. (compression good because it stays closed okay, but will not open properly)
2). Just for kicks try a diffrerent dist. cap. (bad contact on terminal #3 could be missing link in spark path)
Re: Attn engine builders need help troubleshooting 383 [Re: 66Dodge] #747786
07/14/10 10:18 AM
07/14/10 10:18 AM
CA
66Dodge Offline
super gas
66Dodge  Offline
super gas
CA
Okay, we've covered all the basic things that a cylinder needs to fire/combust. Time think outside the box and to look at the weird things that could have happened.
3). Inspect cam lobes in the dist. (worn cam lobe will not close the points all the way, thus no charging of the coil before the points open again)
4). Check for some sort of obstruction in the intake path/runner to cyl.#3. (maybe the ball of aluminum foil was stuffed into intake runner #3 instead of the heat crossover opening ? LOL) (that's why the carb backfired big time ?)
5). Verify you actually saw a spark jump when #3 boot is held close to ground while cranking the engine ?
Re: Attn engine builders need help troubleshooting 383 [Re: 66Dodge] #747787
07/14/10 11:06 AM
07/14/10 11:06 AM
SW Oklahoma
E
epaul Offline
epaul  Offline
E
SW Oklahoma
"3). Inspect cam lobes in the dist. (worn cam lobe will not close the points all the way, thus no charging of the coil before the points open again)
ha, ha
I had a 71 Dodge station wagon given to me that I chased a miss on one cylinder for a few days. I had another 318 I stole the distributer off of and it ran perfect. Funny thing with the old dist. I could re-set the points and it would miss on just one cylinder. If I then re-checked and re-set the points it would miss on a different cylinder. On cam lobe was worn down, nearly impossible to see with the dist. in the engine.
Re: Attn engine builders need help troubleshooting 383 [Re: epaul] #747788
07/14/10 11:25 AM
07/14/10 11:25 AM
CA
66Dodge Offline
super gas
66Dodge  Offline
super gas
CA
6). Spray carb cleaner around the driver's side intake area with engine running to check for vacuum leak ?
