Oil drain plug leaking. Any suggestions? #744683
07/10/10 11:10 AM
07/10/10 11:10 AM
72greencuda Offline OP
I have a deep Milodon oil pan on the 340 in the 72 Cuda, so deep and to low.. I had a low speed scrape the other night and now I have a drip. Anybody have a suggestion after I remove the oil plug? I think maybe in the future I will replace pan with a pan thats not as dangerous. Plug was a little loose after hit,but still leaking after I tightened. Thanks guys.. Wish I was in Carlisle
Re: Oil drain plug leaking. Any suggestions? [Re: 72greencuda] #744684
07/10/10 11:39 AM
07/10/10 11:39 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Aren't the bolts on those on the backside instead of the bottom?
Anyways, wrap the threads of the bolt with a little teflon tape and then thread it into the hole. This should seal the leak + keep the bolt snug. Pay attention to which way the tape is wrapped since if you do it backwards the tape will want to bunch up going in.
Re: Oil drain plug leaking. Any suggestions? [Re: Neil] #744685
07/10/10 11:46 AM
07/10/10 11:46 AM
Yes the bolt is on the backside. Thanks
Re: Oil drain plug leaking. Any suggestions? [Re: 72greencuda] #744686
07/10/10 12:50 PM
07/10/10 12:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You may have cracked the pan, I did that once doing a jump. Right where the drain plug is.
Don't be the exception.
Re: Oil drain plug leaking. Any suggestions? [Re: Supercuda] #744687
07/10/10 04:06 PM
07/10/10 04:06 PM
5thAve Offline
5thAve  Offline
If there's a gasket on the bolt like normal and it's not damaged it doesn't matter if the threads are sealed or not.
Re: Oil drain plug leaking. Any suggestions? [Re: 5thAve] #744688
07/10/10 10:13 PM
07/10/10 10:13 PM
IN
ahy Offline
ahy  Offline
IN
