Recommend an epoxy for my intake #741137
07/05/10 09:29 PM
07/05/10 09:29 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I need to epoxy a piece or two in my al intake. Are the more expensive epoxies like Moroso better than something like JB Weld? I don't need a lot of strength, I think the most important thing would be adhesion to two pieces of al.
What epoxy would you recommend? Thanks!
Master, again and still
Re: Recommend an epoxy for my intake [Re: DaveRS23] #741138
07/05/10 09:52 PM
07/05/10 09:52 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have heard of many other guys using jb weld inside intake manifolds. Seems to be a fairly common practice. I would just be sure the area to be jb'd is clean, roughed up a bit and you cure it under heat for some additional strength. I hope whatever you're epoxying isn't a structural part...
Re: Recommend an epoxy for my intake [Re: DaveRS23] #741139
07/05/10 11:08 PM
07/05/10 11:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Make sure whatever epoxy you chose does not get affected by alcohol.
Re: Recommend an epoxy for my intake [Re: DaveRS23] #741140
07/06/10 05:34 AM
07/06/10 05:34 AM
NL
Frederick Offline
Frederick  Offline
NL
MarineTex gray or A-788 Splashzone for gas engines.
Belzona 1111 for alcohol engines.
Getting a good mechanical bond is very important.
So, make sure you prepare the surface so there's plenty of mechanical "grip", degrease with acetone, and it'll never come out.
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
Re: Recommend an epoxy for my intake [Re: Frederick] #741141
07/06/10 09:39 PM
07/06/10 09:39 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Gas engine, so what's the source for the MarineTex or SplashZone? I have never heard of either.
Re: Recommend an epoxy for my intake [Re: DaveRS23] #741142
07/06/10 11:24 PM
07/06/10 11:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Re: Recommend an epoxy for my intake [Re: DaveRS23] #741143
07/07/10 08:53 AM
07/07/10 08:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gas engine ...
Youu do realize that most all gas sold in gas stations has alcohol in it ... they call it ethanol?
Re: Recommend an epoxy for my intake [Re: Frederick] #741144
07/07/10 10:29 AM
07/07/10 10:29 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
You can get marine tex in any marina or boat store
Re: Recommend an epoxy for my intake [Re: dynamite] #741145
07/07/10 11:32 AM
07/07/10 11:32 AM
Modesto, CA
Chris_Holton Offline
Modesto, CA
You can get the "splash zone" from goodson with there logo on it or just call reher and morrison both have it in stock, I prefer to use j.b. weld around the edges to seal it, and it "feathers" better so fuel and oil cant lift it. I have used gallons of epoxy the last 10 years, splash zone" is the industry standard. Hope this helps...c.h.....
Re: Recommend an epoxy for my intake [Re: Stanton] #741146
07/07/10 02:29 PM
07/07/10 02:29 PM
MI
74_duster Offline
74_duster  Offline
MI
Devcon "F"
http://www.devcon.com/products/products.cfm?familyID=107
Devcon is good stuff. i have heard of it being used in cylinder heads after some overzealous porting. Still Holding years later
Re: Recommend an epoxy for my intake [Re: DaveRS23] #741147
07/07/10 05:15 PM
07/07/10 05:15 PM
Kentucky, USA
RoadrunnerCN Offline
Kentucky, USA
May sound crazy, but I just patch coated some rivets on my aluminum fishing boat with some epoxy I purchased from "Fasco" out of Hileah, FL. Think the website was fasco.com, but search on "Fasco, Hileah, FL" and it should come up (or "aluminum boat patch epoxy). I love the stuff. It worked great and I talked to them on the phone. They were helpful. You could ask if they have some that will not deteriorate with alcohol. They have many, many kinds. On the boat I used "Flex Steel", which has teflon in it for coating the bottom of boats, but again, they make all kinds. Just a thought.
Re: Recommend an epoxy for my intake [Re: DaveRS23] #741148
07/07/10 05:26 PM
07/07/10 05:26 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Will aluminum brazing rod work in your application?
http://search.yahoo.com/search?ei=UTF-8&fr=crmas&p=aluminum+brazing+rod
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Recommend an epoxy for my intake [Re: JohnRR] #741149
07/07/10 07:17 PM
07/07/10 07:17 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Gas engine ...
And even the 10% blend is enough to cause Moroso's epoxy to "unglue" from the intake, as I can confirm first hand.
If there's alcohol in your fuel, find that Belzona stuff someone mentioned above. But don't expect it to be cheap!
Re: Recommend an epoxy for my intake [Re: BradH] #741150
07/07/10 08:14 PM
07/07/10 08:14 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Wow! More choices than I thought there would be. And a little more complexity. Thanks for the help, guys.
