Recommend an epoxy for my intake
#741137
07/05/10 09:29 PM
07/05/10 09:29 PM
Posts: 12,279 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I need to epoxy a piece or two in my al intake. Are the more expensive epoxies like Moroso better than something like JB Weld? I don't need a lot of strength, I think the most important thing would be adhesion to two pieces of al.
What epoxy would you recommend? Thanks!
Master, again and still
Re: Recommend an epoxy for my intake
[Re: DaveRS23]
#741140
07/06/10 05:34 AM
07/06/10 05:34 AM
Posts: 90 NL
Frederick
NL
MarineTex gray or A-788 Splashzone for gas engines. Belzona 1111 for alcohol engines.
Getting a good mechanical bond is very important.
So, make sure you prepare the surface so there's plenty of mechanical "grip", degrease with acetone, and it'll never come out.
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
[Re: Frederick]
#741141
07/06/10 09:39 PM
07/06/10 09:39 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Gas engine, so what's the source for the MarineTex or SplashZone? I have never heard of either.
[Re: DaveRS23]
#741147
07/07/10 05:15 PM
07/07/10 05:15 PM
Posts: 137 Kentucky, USA
RoadrunnerCN
Kentucky, USA
May sound crazy, but I just patch coated some rivets on my aluminum fishing boat with some epoxy I purchased from "Fasco" out of Hileah, FL. Think the website was fasco.com, but search on "Fasco, Hileah, FL" and it should come up (or "aluminum boat patch epoxy). I love the stuff. It worked great and I talked to them on the phone. They were helpful. You could ask if they have some that will not deteriorate with alcohol. They have many, many kinds. On the boat I used "Flex Steel", which has teflon in it for coating the bottom of boats, but again, they make all kinds. Just a thought.
[Re: JohnRR]
#741149
07/07/10 07:17 PM
07/07/10 07:17 PM
BradH
Gas engine ...
Youu do realize that most all gas sold in gas stations has alcohol in it ... they call it ethanol?
And even the 10% blend is enough to cause Moroso's epoxy to "unglue" from the intake, as I can confirm first hand.
If there's alcohol in your fuel, find that Belzona stuff someone mentioned above. But don't expect it to be cheap!
[Re: BradH]
#741150
07/07/10 08:14 PM
07/07/10 08:14 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Wow! More choices than I thought there would be. And a little more complexity. Thanks for the help, guys.
