440-1 pushrod clearances?
#739794
07/04/10 02:24 AM
07/04/10 02:24 AM
Posts: 43,213 Bend,OR USA
Cab_Burge
I bought a set of 440-1 heads last year , trying to install them on my low deck stroker. I noticed witness marks on the heads from the intake pushrods, some angled and some not so angled. My questionis, is it neccessary to use offset roller lifters with the -1 heads or not? I ground the witness marks out on both heads and got lucky on one side, 3 out of the 4 don't rub now, not so lucky on the other sde, all four are rubbing enough to make the pushrods not turn with my fingers at TDC on the firing stroke BTW, anyone not using offset lifters versus how many are using them
Re: 440-1 pushrod clearances?
[Re: Cab_Burge]
#739795
07/04/10 03:11 AM
07/04/10 03:11 AM
i've never needed offset lifters with -1 heads.
[Re: B G Racing]
#739798
07/04/10 10:35 AM
07/04/10 10:35 AM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
Just clearence them,we have to do alot of grinding on the 4 blocks cast in the lifter valley near the deck surface when using the offset lifters.
I mill those pesky things out of the way when bushing the bores. Plenty of power by relocating the intake lifters, using the offset intake lifters, straightening up the pushrods and running a good stiff pushrod.
[Re: CRE2004]
#739799
07/04/10 11:08 AM
07/04/10 11:08 AM
Posts: 16,928 NC
440Jim
NC
I learn something new every day. I currently am runnng 440-1 heads on my 400 low deck with standard lifters (solid flat tappet) with no problem. But looking at my old pics, I can see where using offset roller lifters to straighten out the intake pushrods would move the pushrod toward the casting where I put white arrows.
Thanks for the heads up.
[Re: CRE2004]
#739800
07/04/10 02:25 PM
07/04/10 02:25 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
[Re: B G Racing]
#739801
07/04/10 10:56 PM
07/04/10 10:56 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have .180 offset lifters, needed to clearance the heads without them when I first ran them years ago. Noel Manton of Manton push rods told me to try for .010 clearance at the closest point, that being a minimum. The purpose of shooting for .010 max and min clearance is so that when the pushrod whips (and it will) the pushrod touches briefly, stopping the side motion or flex and calming down the pushrod.
[Re: 440Jim]
#739805
07/05/10 02:02 PM
07/05/10 02:02 PM
Posts: 16,928 NC
440Jim
NC
[Re: 440Jim]
#739807
07/05/10 03:26 PM
07/05/10 03:26 PM
BradH
I don't plan on running a roller cam, or offset lifters, in this engine...
Really? Did you notice I dropped the price of my $chubeck$?
[Re: BradH]
#739808
07/05/10 08:24 PM
07/05/10 08:24 PM
Posts: 16,928 NC
440Jim
NC
This back-up motor is a pump gas short block, and I have my old Scott Brown solid, flat tappet, 272/280 cam and lifters for it that have been used in this block for hundreds of passes. The back-up heads are the EM 470 heads, epoxy ported Mopar Perf Stage VI, that flow about the same as my current Indy 440-1 heads.
I have picked up the used roller cam, used offset roller lifters, etc., just in case I want to try them in my current motor (during an off season refresh).
