440-1 pushrod clearances? #739794
07/04/10 02:24 AM
07/04/10 02:24 AM
Cab_Burge Offline OP
I bought a set of 440-1 heads last year , trying to install them on my low deck stroker. I noticed witness marks on the heads from the intake pushrods, some angled and some not so angled. My questionis, is it neccessary to use offset roller lifters with the -1 heads or not? I ground the witness marks out on both heads and got lucky on one side, 3 out of the 4 don't rub now, not so lucky on the other sde, all four are rubbing enough to make the pushrods not turn with my fingers at TDC on the firing stroke BTW, anyone not using offset lifters versus how many are using them
Re: 440-1 pushrod clearances? [Re: Cab_Burge] #739795
07/04/10 03:11 AM
07/04/10 03:11 AM
i've never needed offset lifters with -1 heads.
Re: 440-1 pushrod clearances? #739796
07/04/10 04:07 AM
07/04/10 04:07 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i had to do a little block & head clearencing with my low deck & -1's & i'm also using offset rollers, but mainly to help straighten the angle.
Re: 440-1 pushrod clearances? [Re: rebel] #739797
07/04/10 06:23 AM
07/04/10 06:23 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Just clearence them,we have to do alot of grinding on the 4 blocks cast in the lifter valley near the deck surface when using the offset lifters.
Re: 440-1 pushrod clearances? [Re: B G Racing] #739798
07/04/10 10:35 AM
07/04/10 10:35 AM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
I mill those pesky things out of the way when bushing the bores. Plenty of power by relocating the intake lifters, using the offset intake lifters, straightening up the pushrods and running a good stiff pushrod.
Re: 440-1 pushrod clearances? [Re: CRE2004] #739799
07/04/10 11:08 AM
07/04/10 11:08 AM
NC
440Jim Offline
440Jim  Offline
NC
I learn something new every day. I currently am runnng 440-1 heads on my 400 low deck with standard lifters (solid flat tappet) with no problem. But looking at my old pics, I can see where using offset roller lifters to straighten out the intake pushrods would move the pushrod toward the casting where I put white arrows.
Thanks for the heads up.
Re: 440-1 pushrod clearances? [Re: CRE2004] #739800
07/04/10 02:25 PM
07/04/10 02:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Re: 440-1 pushrod clearances? [Re: B G Racing] #739801
07/04/10 10:56 PM
07/04/10 10:56 PM
gregsdart Offline
gregsdart  Offline
I have .180 offset lifters, needed to clearance the heads without them when I first ran them years ago. Noel Manton of Manton push rods told me to try for .010 clearance at the closest point, that being a minimum. The purpose of shooting for .010 max and min clearance is so that when the pushrod whips (and it will) the pushrod touches briefly, stopping the side motion or flex and calming down the pushrod.
Re: 440-1 pushrod clearances? [Re: gregsdart] #739802
07/05/10 12:42 PM
07/05/10 12:42 PM
Thanks for the help to all I will probally try grinding the heads for more clearance and look at the pushrod alignment before deciding on using the offset lfters Thanks for pointing out the possible problems on using them 440Jim
Re: 440-1 pushrod clearances? [Re: Cab_Burge] #739803
07/05/10 12:58 PM
07/05/10 12:58 PM
Sk
sp6162 Offline
sp6162  Offline
Sk
On a low deck application Indy recomends
putting the thick spacer between the intake rocker and pedastal.
I know this makes the angle worse but
might save some grinding.
Re: 440-1 pushrod clearances? [Re: Cab_Burge] #739804
07/05/10 02:00 PM
07/05/10 02:00 PM
NC
440Jim Offline
440Jim  Offline
NC
This morning I did a couple mock-ups and trial fits on my back-up engine. This was with Indy 440-1 rockers and Comp 0.180" offset lifters. It didn't take long with a die grinder and carbide burr to clearance those 4 casting bumps, but it did take time to do the trial fits to figure out where it needed to be done, and to make sure it clears.
I don't plan on running a roller cam, or offset lifters, in this engine, but while the block is bare... now is the time to do it.
Re: 440-1 pushrod clearances? [Re: 440Jim] #739805
07/05/10 02:02 PM
07/05/10 02:02 PM
NC
440Jim Offline
440Jim  Offline
NC
Another view.
Re: 440-1 pushrod clearances? [Re: 440Jim] #739806
07/05/10 02:12 PM
07/05/10 02:12 PM
NC
440Jim Offline
440Jim  Offline
NC
One more view with the pushrod installed.
Re: 440-1 pushrod clearances? [Re: 440Jim] #739807
07/05/10 03:26 PM
07/05/10 03:26 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I don't plan on running a roller cam, or offset lifters, in this engine...
Really? Did you notice I dropped the price of my $chubeck$?
Re: 440-1 pushrod clearances? [Re: BradH] #739808
07/05/10 08:24 PM
07/05/10 08:24 PM
NC
440Jim Offline
440Jim  Offline
NC
This back-up motor is a pump gas short block, and I have my old Scott Brown solid, flat tappet, 272/280 cam and lifters for it that have been used in this block for hundreds of passes. The back-up heads are the EM 470 heads, epoxy ported Mopar Perf Stage VI, that flow about the same as my current Indy 440-1 heads.
I have picked up the used roller cam, used offset roller lifters, etc., just in case I want to try them in my current motor (during an off season refresh).
