Harsh drive engagement? #737819
07/01/10 02:07 AM
07/01/10 02:07 AM
65Valiant Offline OP
super street
super street
65 valiant with a 78 904 transmission. Always harsh and clunk noise when putting into drive...tried adjusting the idle and helped a little but the engine almost stalls due to the low idle when at stop lights.
Clunks a little bit in reverse too.
UJoints are fairly new.
Tranmission was rebuilt recently and shifts perfectly, yet still harsh drive engagement.
Any ideas?
Re: Harsh drive engagement? [Re: 65Valiant] #737820
07/01/10 04:27 AM
07/01/10 04:27 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Any ideas?
What sort of rear axle?
Re: Harsh drive engagement? [Re: Pat_Whalen] #737821
07/01/10 04:58 AM
07/01/10 04:58 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
What is the idle speed and what torque convertor are you using?
Re: Harsh drive engagement? [Re: 65Valiant] #737822
07/01/10 07:51 AM
07/01/10 07:51 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
When these cars were new in 64/5/6/etc. many owners, including myself, returned our cars to the dealer with this complaint...when new, or correctly rebuilt these transmissions have a very positive shift, that trait is part of what makes them last a lifetime. Slow easy shifting wears things out. my2cents
Re: Harsh drive engagement? [Re: MO_PA] #737823
07/01/10 09:17 AM
07/01/10 09:17 AM
super street
super street
7 1/4 rear axle, idle set at 950/900, and a stock mopar torque converter, dont know the stall but for a 318/904 from 78 according to my mechanic.
Re: Harsh drive engagement? [Re: 65Valiant] #737824
07/02/10 02:05 PM
07/02/10 02:05 PM
Magnum Offline
Magnum  Offline
If it's a 12" convertor. They are tight. Tight means harsh engagement. This is not to say there is not a problem with your transmission or it can not be fixed by something in your transmission but I've swapped from 12 to 11 before and the engagement was much softer.
Re: Harsh drive engagement? [Re: 65Valiant] #737825
07/02/10 02:08 PM
07/02/10 02:08 PM
NY usa
540challenger Offline
NY usa
7 idle set at 950/900, =
Is that idle in gear or idle in park/neutral.
Re: Harsh drive engagement? [Re: 540challenger] #737826
07/04/10 02:52 PM
07/04/10 02:52 PM
super street
super street
In park the idle is a little higher...maybe 950/1000, and I adjusted the idle so in drive it is at 800.
Looks to be the lowest it will go without stalling when at a light. It actually helped a little with the engagement being harsh going from neutral to drive or park to drive.
I start the car in neutral now as I heard this helps the transmission fluid flow when starting the car cold.
Re: Harsh drive engagement? [Re: 65Valiant] #737827
07/04/10 04:41 PM
07/04/10 04:41 PM
Always harsh and clunk noise when putting into drive. Clunks a little bit in reverse too.
Any ideas?
ring/pinion (excessive) backlash
Re: Harsh drive engagement? [Re: 65Valiant] #737828
07/04/10 05:02 PM
07/04/10 05:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's a lot higher than the normal 550-650, if you have to run it that high to keep from stalling there's a problem with the tuneup.
