Page 1 of 3 1 2 3
Green Bearings for AutoX or road racing #736611
06/29/10 04:41 PM
06/29/10 04:41 PM
Washington State
70chall440 Offline OP
Washington State
Id like to hear from someone who has actually tried using green (non-adjustable) rear bearings for autoX or road racing. I have read tons on the internet and still have not found any definitive on this issue. The urban legend says "no" but all I find is therorethical informaiton, no actual "been there done that" type info. I have seen quite alot of poeple who say they use them w/o issue but no one says in a road race or autox environment. If someone has real data I would like to hear it.
01 Viper GTS ACR
10 Challenger RT PCP 6spd
70 Challenger 440 6 pac
73 Cuda 416 Road Racer
70 Hemi Roadrunner
01 Ram 4x4 / 98 Ram 3500
91 Stealth RT
05 Durango Hemi
09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: Green Bearings for AutoX or road racing [Re: 70chall440] #736612
06/29/10 04:59 PM
06/29/10 04:59 PM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
71 challenger 340 green bearing on 8 3/4. 4 years worth of auto crossing monthly, several track days (Spring Fling Speed festival), zero failures. Below me will be a list of people that say it can't be done. Given the chance I would stay with tapered bearings, but i'm not going to change for the sake of changing.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: Green Bearings for AutoX or road racing [Re: 71autoxr] #736613
06/29/10 05:03 PM
06/29/10 05:03 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Green Bearings for AutoX or road racing [Re: 71autoxr] #736614
06/29/10 05:11 PM
06/29/10 05:11 PM
Washington State
Washington State
I know, I have read volumes of poeple who say it cant be done or it shouldnt be done. I am not debating necessarily which is better, I just wanted to hear from someone who actually can testify to it working or not working. I am building a road race resto mod cuda and am just trying to get the reality of the issue. I read on another forum from a guy running them on a Dart for road race who swears by them, whereas I havent found anyone who says they tried them and they failed.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Green Bearings for AutoX or road racing [Re: HealthServices] #736615
06/29/10 05:11 PM
06/29/10 05:11 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I've never said they can't be used in a handling environment, but it is a known fact that they will not take the side loads that a tapered roller will take, so when given the choice, WHY use the "weaker" solution?
Re: Green Bearings for AutoX or road racing [Re: Jim_Lusk] #736616
06/29/10 05:26 PM
06/29/10 05:26 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
I'm glad I'm not the only guy who hates Green bearings.
I can't say much about road racing but I have seen 3 guys with Green bearings come apart during normal street use. In one case, the seal failed and the bearing got condensation in it and rusted up to the point of failure. The other two, who knows why they failed but they got 'grumbly' and just came apart over not very many miles.
I routinely get in fight with axle companies when I try to order axles with the proper Mopar journals. Strange screwed up a pair for me last time, I still have them and they are good for Green bearings only.
Re: Green Bearings for AutoX or road racing [Re: GregCon] #736617
06/29/10 05:35 PM
06/29/10 05:35 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Why would anybody chance it? Just because a few people have had it work doesn't mean we all will. The strength is no contest.
You won't have a list of people on here say their stock bearings failed before their time, let alone pushed to the limit in a road race app. Green bearings? We already have one.
I want my fair share
Re: Green Bearings for AutoX or road racing [Re: HealthServices] #736618
06/29/10 06:06 PM
06/29/10 06:06 PM
Florida STAYcation
dOOc Online penguin-006
The village idiot's idiot
dOOc  Online Penguin-006
Florida STAYcation
And to the people who say you HAVE TO try-it ...to report on-it.....
.... do you need to fill your crankcase UP with water ....to KNOW that the motor will seize-UP in short order ?
Re: Green Bearings for AutoX or road racing [Re: Jim_Lusk] #736619
06/29/10 06:09 PM
06/29/10 06:09 PM
Washington State
Washington State
the "known fact" issue is exactly what started this thread. Everyone says it but no one has offered any real evidence other than saying that it is a "known fact". To answer your last question I would say because of ease of use, ease of installation and ease of axle/rear gear swap. I am not arguing for the green bearings, I am just trying to determine if they have recieved a bad reputation undeservedly. I have them in my 70 Challenger and never had an issue, however this isnt saying alot because I havent racked up the miles on them nor have I pounded on them in corners. 71autox is the first guy I have heard from that has stated he is using them and has an opinion based on experience. Not trying to challenge anyone's beliefs here, just want some reality.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Green Bearings for AutoX or road racing [Re: dOOc] #736620
06/29/10 06:18 PM
06/29/10 06:18 PM
Washington State
Washington State
I think this is a little bit of an extreme contrast. Water in the crankcase is a far cry from this subject. Green bearings have and are being used by many. If you dont like or want them, then dont use them. However I started this thread in an attempt to see if there was someone out there that was or had used them in an autox or road race environment and would share thier experince. Just because someone doesnt hate them doesnt mean they dont work. this isnt blasphemy if someone actually likes them; it is personal opinon and I personally perfer opinion based on experience. This isnt a slam on tapered bearings or another version of "what is best". This is purely a question of green bearing experience as it relates to cornering.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Green Bearings for AutoX or road racing [Re: 70chall440] #736621
06/29/10 06:22 PM
06/29/10 06:22 PM
scratchnfotraction Offline
ran my first set 9 yrs daily 80 miles a day
2nd set 2 yrs now daily 80 miles a day
I drive on the street almost as hard as an autox
does that count????
the biggest thing I have read on here is about the thrust button and side loads
I have ran them with and with out the thrust block with no adverse failures
done lots of figure 8s,burn outs,power slides,drifting...some what..not enuff HP to keep it in the drift slow speed to trip didgets
ran them as hard as I can for 9 yrs and have not had a problem so far on the street,have bent 2 of the rear weld wheels sliding around and hitting potholes ect...
skeerd say your skeerd...I am skeerd! ...not!
my worthless on them
i say go for it...he did on a autox machine
I have seen enuff with mine, I would
Re: Green Bearings for AutoX or road racing [Re: scratchnfotraction] #736622
06/29/10 06:26 PM
06/29/10 06:26 PM
Washington State
Washington State
does that count????
skeed say your skeed...I am skeed! ...not!
that is the "experience" I was looking for. Seems they are not as bad as some would have you believe. At the end of the day I am not sure what I will use but at leastI have heard from someone that doesnt just say "never". Thanks.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Green Bearings for AutoX or road racing [Re: 70chall440] #736623
06/29/10 06:38 PM
06/29/10 06:38 PM
run them in my truck also
done plenty of hauling,work,muddin,offroad
setting up my 440 truck with an A-body 8 3/4 with them also
I am not skeerd of them
when my one bearing went out,I think it was from a empty car dolly that had a wig wag to it (no thrust block)
70 mph for 250 miles,hauled a truck back smooth as glass,few days later it was toast and growling leaking oil thru the bearing itself...never broke or anything just leaked oil and had slop up and down in the bearing
2nd sets been fine so far and just as much on them
boy was that anoying,wig waging for 250 miles
Re: Green Bearings for AutoX or road racing [Re: scratchnfotraction] #736624
06/29/10 07:14 PM
06/29/10 07:14 PM
Washington State
Washington State
Appreciate the information. I installed them on my Challenge because they were easy to install and a better option at the time than tapered bearings. As I am planning this next car I wanted to know what my options are and plan a direction.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Green Bearings for AutoX or road racing [Re: scratchnfotraction] #736625
06/29/10 07:14 PM
06/29/10 07:14 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
It sounds like you're just wanting to hear what you want to hear.
I gave you three cases I know of where they failed. I can't think of a single case where a tapered roller has failed. I've seen some wear out over 200K miles but that's not really a failure.
We're all hot rodders of some sort. We all like to do things that improve our vehicles. so why go to a bearing that, in addition to being very Chevy-like, is inferior in design?
It would make my car easier to get parts for, and easier to work on, if I installed a small block Chevy instead of a Hemi. But that's hardly an excuse to put poop in my car.
The biggest complaint I have with Green bearings is the aftermarket has flocked to them (because they are stupid Chevy guys) and it has made it harder and harder to get parts and pieces for the proper tapered rollers. As I mentioned, it is getting hard to find an axle company that can grind an axle for normal bearings. It's kinda like turning in the radio - we used to hear Hendrix and now we get Michael Jackson.
Re: Green Bearings for AutoX or road racing [Re: GregCon] #736626
06/29/10 07:39 PM
06/29/10 07:39 PM
SomeCarGuy Offline
SomeCarGuy  Offline
I've run taper bearing in everything for years and years and years and years...
Never had one fail.
Pushed cars hard in corners, all that.
Is that enough personal experience for you or am I another one that just doesn't know anything because it doesn't support what you want to hear and/or believe?
Re: Green Bearings for AutoX or road racing [Re: GregCon] #736627
06/29/10 07:43 PM
06/29/10 07:43 PM
that would be 4x if you count my failure
I have had a stock tapperd bearing go out also
due to incorrect endplay adjustment and greese getting washed out from a seal leak
oh I run my greens this go round with out axle seals in the housing also
o-ring seals it fine
the adjuster/lock tab is no longer made and very hard to get/find nowdays another reason I went greens
been sliding this A-body axle around in my truck for yrs with fattys and 12" rims
when they go bad i will knock them off and hammer another set on
he asked..I said...no pizzing contest...
he said he didnt want to hear better or worse just who has on them
run what ya brung
Re: Green Bearings for AutoX or road racing [Re: 70chall440] #736628
06/29/10 09:54 PM
06/29/10 09:54 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
All the major motorcycle manufacturers switched from using ball bearings in the steering head (the part of the the frame where the front suspension is mounted) to tapered roller bearings because the ball bearings would consistently develop a "notch" in the normal range of steering motion, typically right in the center where most loads occured.
Ball bearings are bicycle-grade technology. There's no way I'd run 'em in any axle application where they'd be expected to deal w/ significant side loads.
Re: Green Bearings for AutoX or road racing [Re: 70chall440] #736629
06/29/10 09:58 PM
06/29/10 09:58 PM
Under My Car
Mopar_Country Offline
Under My Car
Well, all I have ever run is tapered, zero failure. With that said put the greens in and if they work they work, if they fail they fail then you will have the experience you are looking for. I have talked to other folks around here that run them and they have had good luck with them, but most of them only drive their car 4-5 hundred miles in a season.
Re: Green Bearings for AutoX or road racing [Re: 70chall440] #736630
06/29/10 11:24 PM
06/29/10 11:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The great pissin/moaning debate of Green vs Taper, on "paper" the taper is by all accounts a superior design, but so is bulletproof glass, do I need that on my car also?....I've been installing the Green bearings for well over a decade on my cars, as well as customers cars, not one failure, showcars to roadracers, drag racers to street bashers, hard miles, track time, long distance, constant abuse street or track,....I've encountered quite a few failures with tapered bearings, including 2 axle losses,(shaft leaving the housing) often due to excessive HP and roadraceing, hence the prefered change to Green bearings, I was skeptical at first also using "Green" bearings in something other than a Drag only car, but seeing that I've had zero failures with Green bearings in a multitude of my personal and/or customers cars, vs multiple failures with tapered bearings, I'm more inclined to endorse the use of Green bearings for street and/or track,(drag or roadcourse) of course proper installation and premimum parts are a mandatory criteria for maximum performance and reliability.......See Dr Diff on the Moparts board for your required application
Mike
Page 1 of 3 1 2 3
