Buddys OLDS ran 12.80,, My car WONT HOOK,
#735235
06/27/10 11:21 PM
06/27/10 11:21 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
He has a 65 Old with a pretty decent 455 in it. I ran a 13.2 @ 106 with my 360. Now My 408 is damn near done, and Im kinda worried my car wont hook. My 60 ft times were terrible. 1.99 was my best, Its a 4 gear car, and the M/T et drag radials werent hookin at all. Someone told me my Summit brand shocks are too short and thats my problem. I have SS springs, and a pinion snubber, and I had the air to 11 psi. I was told thats too low. Any ideas here. I did buy the Xlong mopar performance shocks, and they are only about 1/2" longer than the summit shocks. I know Im puttin more HP out with my 408, he might have me on torque. But I would hope my car will run 12.50s all day long. Randy who sold me my B1bA brodix heads said it should do that with 1 plug wire off. But I have to get my traction issues figured out, and the summer is dwindling fast, and Im still waiting on TTI for a #7 header tube.
Any pointers here would be great. I have contemplated buying the caltrac bars, and running them on the SS springs. The bad thing here is I dont want to put a cage in my car. Its a street car mostly, and I hate the bulky looks of a cage. What times require I run a cage?
Thanks in advance guys. Oh im running 3.91 gears...
KAsey
Re: Buddys OLDS ran 12.80,, My car WONT HOOK,
[Re: MIKES_DUSTER]
#735246
06/27/10 11:57 PM
06/27/10 11:57 PM
Posts: 6,293 Northeast, Alpine, NY
9 Sec Phill
On a road near you
On a road near you
You need more air in the radials for them to work, start at 18 psi and go up 2 psi till it slows down. then lower 2 psi till it slows down. You will find what the tire wants. Mine was 18psi..Loose the snubber and clamp the front segments of the springs. The MT radials need some heat into them to hook. How are you doing your burn out? dont sound like your getting any wheel speed in the burn out to make any heat. If all else fails just leave easy and im sure you will at least get a 1.7 60' time....Phill
[Re: 9 Sec Phill]
#735247
06/28/10 12:06 AM
06/28/10 12:06 AM
Moparnut426
Thanks Phill, I questioned my Burnout also. My car really wanted to walk to the left, and almost into a guard rail, and I never got a chance to try the other lane. I did a good burnout I thought, good smoke, and held it there for a while but Im honestly a little new at the track, only been down it about 4 times with this car. Now with the new engine almost in it, I want to straighten any potential issues beforeI run it again.
I know a new engine making more HP is just going to make spinning a bigger hassle.
Kasey
[Re: MIKES_DUSTER]
#735249
06/28/10 12:18 AM
06/28/10 12:18 AM
Moparnut426
Well, Id love 500, I was told it should make 535, but I doubt that. I cant afford to dyno it, so Im just gonna have fun with it. Its got Great heads, they were on a 416 that made over the 500 hp mark, and Im just runnin less cam that he had. I have 10.8 compression, solid roller cam, K1 crank, Child track master rods, Hughes main stud and girdle set up, and toipped off with a Quick fuel Carb thats a 750 slightly opened up from them. I bought the carb second hand and was told its an 800ish cfm. Ran good on the 360, might need jetted up a tad on the 408. Kasey
[Re: Moparnut426]
#735250
06/28/10 12:29 AM
06/28/10 12:29 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
all the posts ive read the MT's like more pressure than that, 16-20, i'll be in the same boat here soon testing mine
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Joshs68]
#735255
06/28/10 09:13 AM
06/28/10 09:13 AM
I'll say it again.......90% of making one hook is in the FRONT END, especially with a drag radial.........How loose is your front end and what kind of shocks???? You're running 106 now, and that's enough for 12.40's with an automatic, slicks, and a 4,500+ converter...........If you want to run 12.50's with a 4-speed, you're going to have to work your butt off.........and by that I mean you HAVE to drive it like you stole it by power shifting and launching pretty high (like 4K+), so you'll need a good clutch......... BTW, throw the snubber in the trash.......
[Re: CokeBottleKid]
#735258
06/28/10 09:39 AM
06/28/10 09:39 AM
Posts: 2,023 Lincoln NE
440forPOWER
super gas
super gas
Lincoln NE
I think the 106 was with his 360 not the stroker. Where did you guys run? SD? or Kearney/
[Re: Moparnut426]
#735259
06/28/10 09:49 AM
06/28/10 09:49 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
The rear of your car looks high (I like a high rear and rake to) so you probably need a set of these http://chucker54.stores.yahoo.net/reshex.htmlOh cal trac 90/10 shocks trim the bump stops so front end has 5 to 6" of travel (rise from sitting) Unclamp the back of springs last clamp should be maybe 8 to 10" behind axle! Cal trac Bars with bite!!!!!!!!!
[Re: Dodgem]
#735260
06/28/10 12:22 PM
06/28/10 12:22 PM
Moparnut426
Ok, been at work.
Car has /6 bars, and 90/10 front shocks. Its got 3200 il ss springs in it now. I have a line lock on it, but Its not hoocked up yet. Dont really want to use it if I dont have to. Car has a centerforce dual friction clutch. Its been good so far, But my new engine might kill it. I ran 106 with the ol 360 in it.
We r running Marion SD, and Kearney. WISH SCRIBNER WAS STILL THERE!!!
Thanks guys. Lots of info here. Soo You guys thing I need to loose my snubber, clamp the front of the springs, un clamp the rear springs, and run more PSI in the tires?
Im gonna need a loop for the drive shaft now also. I think the last time I left at 4K with the old 360, I was gonna leave around the same with the new engine.
Much apreciate the help guys...
Kasey
[Re: Dodgem]
#735261
06/28/10 12:36 PM
06/28/10 12:36 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
You really want the car as level as possible so it'll trnsfer wqeight easier, mines about a 1" rake, not 3+ inches like most mopars i see, they have all kinds of problems hooking, being a stick car, like said, you'll need to "drive it" HARD to see mid 12s, but it'll do it with a 106 mph, your 60fts. should be around 1.78s or there abouts, i'm running 12.6s @ 104-105 with 60fts. consistant on EVERY pass in the 1.82s, My MTs are at 17 lbs. "cold", so there about 19-20 hot, rim width vs. tire size is also important for a nice footprint, a good footprint & you can run more air pressure, i'm on 7" rims with a 255/60/15, so i have to be careful not to exceed 19 lbs. cold, it won't hook, i've also stated running a snubber for trial basis, its about 1/2" from the floor, I also installed CE shocks up front, beleive it or not, my 60fts haven't changed, 1.82s is where there at in the heat, my best was a 1.79 in early may, i've also install clamps in the front of my rear springs, installed longer shocks, un-clamped the rear straps, & installed a thick spring on both sides, car still 60fts. the same , Now i'm sure once i juice it things will change. With the rake on your car, you really need the front to be as loose as possible, & have enough lift to overcome the back, this will help, now are you sure you have enough pinion angle? Look at this video of my car, as you'll see it sits pretty level, notice even on 1.82 60fts. it doesn't transfer a hole lot, this track is tranction limited on some nights do to its prep, i do on accasion squak 2nd., but i'm still very consistant on the 60fts. & that whats important. web page
chico
[Re: Moparnut426]
#735263
06/28/10 12:45 PM
06/28/10 12:45 PM
Posts: 7,861 Witness Protection Program
Kudakidd
I love rowing gears, Always have, but I dont think thats my issue. Id like someday to build a decent 904 for it, but then I hate to de-convert my 4 Speed car. I spent a lot of time and effort switching this car to a 4 speed.
Damn straight. Real muscle cars have 3 pedals! Try a good smokey, then leave the line at about 1-2k rpm.
[Re: joedust451]
#735264
06/28/10 12:46 PM
06/28/10 12:46 PM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
hook up that line lock!!!!! you need it for a straight burnout and on the line so you don't roll out of the beam's and waste a pass!!!
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
[Re: Moparnut426]
#735265
06/28/10 12:48 PM
06/28/10 12:48 PM
joedust451
super gas
super gas
Branson, Mo.
Well The car doesnt look the same as in my sig, cant remember how to change sig pictures. And the pinion angle is 3 degrees.
Kasey
Not enough, you need a good 6-7 degrees, especially with a stick car.
[Re: joedust451]
#735266
06/28/10 01:31 PM
06/28/10 01:31 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
Kasey
What about a auto??? My SS springs are going in tonight. My new front hangers JUST arrived!!!!
[Re: MIKES_DUSTER]
#735267
06/28/10 02:13 PM
06/28/10 02:13 PM
Posts: 1,178 Indy
FlyFish
Indy
IMO, with the new motor you will run mid 12's only if you miss shift AND forget to go to 4 gear. The new motor will run 11's with ease. I agree, more pressure is needed in the drag radials...probably at least 16-18 lbs.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: joedust451]
#735268
06/28/10 03:50 PM
06/28/10 03:50 PM
Moparnut426
Kasey
HOLY CRAP!!!
That seems like a LOT of pinion angle, Hows that gonna affect the street driving?
Kasey
[Re: mshred]
#735271
06/28/10 05:45 PM
06/28/10 05:45 PM
MIKES_DUSTER
if your car is a stickshift id be done with those et street radials and put on some bias ply et streets (the DOT slicks they sell)...that should definatly help some...bias ply is the only way to go and hook with a stick car...and the traction on the et street is the same if not better than the radial
IF you are going to do this??? Get QTP's!!!!
[Re: CokeBottleKid]
#735274
06/28/10 06:15 PM
06/28/10 06:15 PM
Quicktree
106 is aenemic for a stroker with those heads...
You need to do some tuning/check for issues.
is the heads ported? I wouldn't call them great heads either way
[Re: MIKES_DUSTER]
#735275
06/28/10 06:29 PM
06/28/10 06:29 PM
joedust451
super gas
super gas
Branson, Mo.
Kasey
I'd say about -3,-4*, i run mine all the time at this, drive the 100 mile round trip to the track, make 3-4 passes & go home, the car is so smooth on the highway its comfee
Mike, you need to check your trans tailshaft angle to set the pinion angle currectly, mine is set at 0*, my pinion is down -3*.
[Re: Moparnut426]
#735278
06/28/10 09:27 PM
06/28/10 09:27 PM
Ok, been at work.
I'LL SAY IT AGAIN, 90% OF MAKING ONE HOOK IS IN THE FRONT END ........Throw the CE shocks in the trash and buy some Cal-Trac front shocks.......Make sure it's got either urethane upper control arm bushings or heim joint control arms..........Use urethane bushings in the lower control arms...........and use heim joint strut rods.............
Yes, AND install urethane front spring eye and shackle bushings........
Soft sidewall tires will be better than drag radials with a 4-speed, because they'll absorb the shock of dumping the clutch (as most know, shocking drag radials doesn't work).......BUT, it's not like you have a ton of power with the 360, so if it were me, I'd do all the suspension stuff (because you need that anyway) and go to a soft sidewall tire as a last resort.......
#735279
06/28/10 10:55 PM
06/28/10 10:55 PM
Posts: 3,415 Toronto
mshred
Toronto
Ok, been at work.
with a 4 speed you dont want soft sidewall tires, you want a stiffer sidewall, in fact as stiff as you can get...with a soft sidewall like a drag radial, the initial hit from the clutch wil cause less control and stability and therefore less traction...the stiff sidewall of the bias ply will help to absorb and plant the power while pointing the car straight...thats why stick guys are almost always running tubes as well, anything to help stiffen those sidewalls
#735280
06/28/10 11:06 PM
06/28/10 11:06 PM
Moparnut426
Im not running the 360 anymore, My stroker is done.
Im a bit confused on the side wall deal. I always thought the drag radial were stiffer on the side wall. The bias ply "wrinkle" walls are softer, flimsier???
Thats why the bias tires are so squishy down the road.
Kasey
[Re: Moparnut426]
#735281
06/28/10 11:15 PM
06/28/10 11:15 PM
mshred
Toronto
Kasey
the way the chords are wrapped inside a bias ply tire is different from that of a radial and favors itself more for stickshift driving...they are stiffer...look on a stickshift race car and guranteed you will not ever see a radial, always a bias ply
ive read of guys who have picked up a couple tenths just from switching from dr's to a bias ply...some even more than that...its pretty amazing actually
[Re: Moparnut426]
#735282
06/28/10 11:16 PM
06/28/10 11:16 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
kasey If you find the car still moves over during a burnout.. take more time setting tire pressure. and get a guage that reads in .25 pounds increments.. most times i find a car moves sideways during the burnout..its cause the tires arent air'd the same if you have a guage that only goes in full pound increments..you could be off from right tire to left tire..this will give you sideways burnouts and also kill any attempts to get traction.. get or borrow a large face gauge..with 1/4 or better 1/16 lb increments.. on the 6* pinon angle...id just be aware...that you street drive the car and down shift to engine brake...id be a little leary with 6* of pinion angle.. and down shifting.. if you go with 6* and find that it shakes under deceleration...you know were/what that issue is... fwiw.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#735284
06/28/10 11:28 PM
06/28/10 11:28 PM
9 Sec Phill
On a road near you
On a road near you
CSD, I would have to disagree with you on this, I know the air presure will very but the it has nothing to do with having the same presure in each tire. All tires are not the same hieght even if they are both 275/60/15's...One might be 28" and the other might be 29 1/2. He needs to check the roll out of each tire, take a tape measure and go around the tire and see if they are the same at 18 PSI, if not add air to one and let air out of the other, what ever it takes and to be safe with the presures till the tires have the same roll out or size. This will help the car launch straight and keep the car straigh in the BO box. My ...Phill
[Re: mshred]
#735285
06/29/10 02:18 AM
06/29/10 02:18 AM
joedust451
super gas
super gas
Branson, Mo.
Ok, been at work.
Is it me or do you have it backwards, DRs have a stiffer sidewall, Slicks are Bias ply, they wrinkle, they do make a stiffer sidewall slick, but you do want a softer hit with a stick car, DRs (if under enough power) will not over-come the hit or shock when dumping the clutch & high RPM, ET streets or QTPs will work much better, they have a softer sidewall.
Many on here will tell you with SS springs you need more pinion angle, especially with a stick car, a good 5-7 down, now driving it on the street you may feel vibration with no load or costing/de-exec., your U joints won't last as long, but if you can control the wrap up on the springs (with clamps), then you can get away with less angle, you just don't want to go in the +. This will cause "wind-up" & will let the pinion snap back down, in turn cuaseing wheel hop/porpasing & or blowing the tires loose, more or less once your in the + (pinion up) you loose torque multiplacation through the DS & too the pinion, if this makes sence.
[Re: mshred]
#735286
06/29/10 08:29 AM
06/29/10 08:29 AM
In his case, I don't agree with that.......That would be OK IF the car was hooking........
That's backwards.......The drag radials he's running have much stiffer sidewalls than Hoosier Quick Time Pros.......
Stick guys run do run tubes to make the soft sidewalls last longer......
#735287
06/29/10 04:25 PM
06/29/10 04:25 PM
mshred
Toronto
i dont think i have it backwards...when a radial tire hits with a stick car, the way the chords are wrapped causes a rebound that is detrimental for traction...in a bias ply tire the way the chords wrap absorbs but allows the car to point straight and hook, so there is less "rebound"...Stick racers are always looking for a stiffer tire, which is why tubes are run in them...
i mean i could be wrong here, but this is what i have heard many stickshift guys say, stiffer is better...it is only from this that i can assume that bias plies are stiffer, especially if they have less recoil as compared to drag radials on the same application
[Re: 9 Sec Phill]
#735288
06/29/10 05:52 PM
06/29/10 05:52 PM
cheapstreetdustr
I wont agure/disagree with that....
[Re: mshred]
#735289
06/29/10 07:35 PM
06/29/10 07:35 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Keep at it but it's not that way.
Wayne, you hitting your head on the wall yet?
Pinion angle, clamps, lower the rear if possible and work the crap out of the front end as suggested. It's a 12.40 ride with the current MPH with everything going your way..
[Re: JCCuda]
#735292
06/30/10 12:29 PM
06/30/10 12:29 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Kasey... first things first.. Get the motor in the car and take it for a spin.. Your combo sounds an aweful lot like my old combo.. 410 stroker, 4-speed, 391 gears, wrong shocks, etc.. and I have to admit, I chased troubles and inconsistencies for a couple of years..
That combo you have should easily run low 12's and at upwards to 115-119 mph, all depending on how much spin you get at the line.. To put this all into perspective, my combo ran all over the 12's.. From low 12 to high 12 between back to back passes and then one day out of no where, popped in a mid 11..
Tired of fighting (and losing races) with the 4 speed, I got fed up and put in a reverse manual 727 and there has been no looking back.. First pass with the new tranny was a 11.6x and all weekend long, I was within a .25 seconds while learning shift points and etc..
My recommendation to you is to first put 20lbs of air pressure in those E/T's... screw the QTP's, screw the bias crap.. E/T's will work!!!
Next I would launch at 2000 rpm, then 3000 rpm, then 4000 rpm to see which rpm the car liked the best.. After that, play with shift points to see what how the motor works and then once you get that out of the way.. come back here and tell us what happened.. The fine tuning of the car/suspension/launch can only happen after you take the car on its maiden voyage..
[Re: JCCuda]
#735293
06/30/10 12:32 PM
06/30/10 12:32 PM
Posts: 1,260 Netherlands
72Challenger
Netherlands
Last years I've ran a 4-speed in my 10sec running street/strip car. 72 Challenger weighing in at around 3750lbs.
I got rid of the front sway bar (or just loosen the side links at the track), had some CE 90/10 shocks in the front, caltracks w/ oem leafs in the rear. D60 w/ 4.30 gears turning GY 30x11.5 slicks. Leaving at 5k of rpm I had no traction issues at all? Before with Hoosiers I had some but with the goodyears none. I guess if you just get some sticky tires you should be fine.
Now I have the same engine in a strip only challenger weighing in at 2700lbs with a GForce clutchless behind it and still have no problems hooking up with 1.3 60fts running 9's the 1st time out.
Stick to the stick, it's the most fun!!
[Re: Jeepmon]
#735294
06/30/10 12:39 PM
06/30/10 12:39 PM
Moparnut426
GREAT ADVICE!! Finally someone chimed in with a similar set up. I did forget I put a swey bar up front. Thats gonna go Bye Bye, or atleast make me some disconnects for it.
Thanks for the ideas.
Kasey
[Re: Moparnut426]
#735295
06/30/10 03:07 PM
06/30/10 03:07 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Radials are not recommended for 4-speed cars. Just ask the tire manufacturers. The sidewall on radials are stiff and then they require more air pressure for less rolling resistance. This is why radial tires are faster. In Stock Eliminator everybody runs radial slicks, except the 4-speed guys. Radials are not forgiving enough for four speed cars. When a radial starts to spin they don't stop. I run M/T pro drag radials on the Stocker Volare and my Challenger. They require a lot of chassis tuning to work on a consistent basis. You would be better off going to a true drag slick for the best results. Our Duster runs a M/T 28*9 slicks and runs 11.50's at 3200lbs with stock suspension. Good luck.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
