Re: acid ported intake manifold
[Re: stage3]
#735018
06/27/10 10:26 PM
06/27/10 10:26 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Looking for anyone that does acid porting on intake manifolds for small block Chrysler. Have got prices on extrude honing and would like to know what acid goes for and what benefit either offers. Car is not legal for any sanctioned CLASS racing, just want a stock appearing car. Thanks in advance for any help. I have heard of Walters intake manifolds but no contact info.
Be ready to crack your wallet open. If you are porting a 2 plane manifold you are probably just wasting your money.
[Re: NoFrills]
#735021
06/28/10 09:50 AM
06/28/10 09:50 AM
BobR
Left Coast
my brother used to run a circle track small block chevy that had to have a stock intake and had some some stuff from this guy they spilit the intake port then weld back togeather and hide it all in the end http://www.castheads.com/
Several years ago A local Mopar stock eliminator racer told me that he had about 6 grand into SB thermoquad manifold. He figured that it was worth about .06/2mph.
[Re: stage3]
#735022
06/29/10 12:20 PM
06/29/10 12:20 PM
Posts: 4,206 New York
polyspheric
New York
What it does: removes material very slowly from the entire interior surface (not just the parts you want, or casting flash and machining errors). Any area that isn't clean won't get ported. If you know where you want it ported, mask the other areas with something acid-resistant such as wax. Don't melt wax into the manifold, it won't come off the areas to be ported by scraping. It may get hot enough to melt the wax anyway. Chemical: for cast-iron, most strong acids will work but very dangerous to handle. Aluminum, you can use lye or acid, but they work much faster. Never add water to acid - you add acid to water. Put it outside, plug the port runners, leave the flange open and fill with acid. It probably affects the bottom slightly more, as bubbles will tend to follow the walls upward. Best results: plug everything, and rotate it 90° every 15 minutes for several hours, drain, examine. Wear rubber gloves, goggles, respirator (not just a mask). Tell someone to call you back, and call 9-11 if you don't answer. Throw away whatever you wore.
Boffin Emeritus
[Re: polyspheric]
#735023
06/29/10 01:51 PM
06/29/10 01:51 PM
Posts: 12,391 Taxes & Virus's R-US, NY
Dragula
The EPA called and said they will be right over.....
[Re: stage3]
#735024
06/29/10 02:33 PM
06/29/10 02:33 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
The proceedure is pushing the better part of 500. nowadays. Unless you absolutly have to have it its worth is marginal at best.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#735025
06/29/10 03:10 PM
06/29/10 03:10 PM
Posts: 3,504 DFW
mr_340
DFW
I remember a Pro Stock racer was letting the car body sit outside to rust and then cleaned it up with muriatic (HCl) acid. I think it was Glidden, but maybe you could do that with your intake. Have it tanked and paint the outside and mask the areas you don't want to rust and let it sit outside for a year or so. My experience with muriatic acid is the metal is very active and will start to rust again immediately after pulling it out and drying it off. NHRA doesn't let you paint the interior of the intakes or any coatings, so it will need to be removed before teardown. Maybe you can find out what Waltrip used on his Tyoder manifold years ago?
Floyd Lippencott IV
[Re: mr_340]
#735026
06/29/10 06:05 PM
06/29/10 06:05 PM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
Sterno, heard he had so much in there that they just threw the jets away.......LOL
[Re: mr_340]
#735027
06/29/10 06:41 PM
06/29/10 06:41 PM
polyspheric
New York
True - any chemicals use must not only be flushed, but neutralized with baking soda, etc. (reverse pH factor). Test water must come back 7.0. The acid-dipped S/S and steel funny cars all disintegrated into piles of dust, except the one (Landy?) who neutralized his. It's almost cost-effective in supplies (the acid actually used is much, but you need a lot for the fill), but it's labor intensive and scary to do, and dangerous.
Boffin Emeritus
[Re: polyspheric]
#735028
06/30/10 02:23 AM
06/30/10 02:23 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
No acid experience here, but i did modify my 71 340 intake, milled the divider and blended the plenum area, tried best i could to radius the "90's " in the ports, gasket matched also, there was a lot of metal removed just from the gasket match. probably got 30 to 40 hours in the intake and about $20, looked into thermo coatings and was quoted $120 to do the bottom of the intake and the carb flange area but i passed. your best bet is to at least deep port gasket match it.
