Ok, I took my deep pan off again. And I thought that I found the problem. I was so excited!
When I laid a straight edge across the front of the pan rail (the rail that meets the front of the tranny), there appeared to be a little bend... exactly where it leaks (on the passenger side front corner). That was the only place that it didn't appear to be straight.
So rather then try to straighten it (and perhaps make it worse), I bought a new pan.
But this one appears to be bent in the same area.
So I'm ready to sell the car. Any takers? (just kidding!)
Now I'm thinking that I have a couple of options. 1) try and straighten the old one or 2) try the new one as is.
It came with a new rubber gasket that is less than 1/8" thick.
Does anyone know, am I supposed to use any sealant?
Thanks!
Tim...
