Cork or Rubber? Tranny pan gasket... #733623
06/25/10 10:20 PM
06/25/10 10:20 PM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Ok, I need to change the gasket on my 727 transmission pan. I used cork before, with some sort of blue RTV.
I'm not sure that it ever stopped leaking! A dribble here & a dribble there.
What do you suggest?
I have a rubber gasket.
But I'm used to cork.
If I use the rubber gasket, what RTV should I use?
I'm temped to use cork again, but with Permatex 2. Putting the gasket on the pan & letting it dry overnight. Then applying the same sealant with a dab on each screw...
Any help would be greatly appreciated.
Thanks!
Tim...
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: Cork or Rubber? Tranny pan gasket... [Re: cuda_tim] #733624
06/25/10 10:36 PM
06/25/10 10:36 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I used a soft rubber gasket and clear GE Silicone I door and window sealant on my pickup transmission and it worked nicely. The GE silicone is available at home depot and lowes and it works better than any parts store rtv I have ever tried. It's super sticky and sets up pretty fast so have all your parts cleaned and ready to roll once you start applying it.
As with any sealant you need to make sure the surfaces are super clean. I went over the trans case surface with paper towels and carb cleaner several times in order to get it as clean and oil free as possible.
Re: Cork or Rubber? Tranny pan gasket... [Re: cuda_tim] #733625
06/25/10 10:39 PM
06/25/10 10:39 PM
ne
broncobra Offline
broncobra  Offline
ne
Don't use rtv. Use Indian shellac or some thing else, or get one of those rubber/steel insert gaskets. RTV can get small blobs gunked up into everything, use a painted on type sealer.
Re: Cork or Rubber? Tranny pan gasket... [Re: broncobra] #733626
06/25/10 11:07 PM
06/25/10 11:07 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Go to a Dodge/Chrysler dealer and get the newer style reuseable pan gasket. The number for the 727 (or A-518/46RH/46RE) is: 2464324AC. It is hard nylon over steel with molded in double sealing beads. Be careful not to overtorque it, or you can strip the case threads because it doesn't compress the same as a cork or rubber gasket.
Re: Cork or Rubber? Tranny pan gasket... [Re: Reggie] #733627
06/25/10 11:58 PM
06/25/10 11:58 PM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
I agree. It will be the last pan gasket you ever buy. Well worth the money.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: Cork or Rubber? Tranny pan gasket... [Re: 71autoxr] #733628
06/26/10 12:24 AM
06/26/10 12:24 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
As long as the pan-rail is straight and flat ...and you do NOT over-torque the bolts ....
......ANY gaskets will work.
I have a cork one on my 62 since the late-70's ... on and off maybe 8 or so times .....NO problem.
And NOTE ... if you are chancing STRIPPING the threads in the case by OVERtightening ... you are using about FIVE TIMES ++ ... tooooo much torque on these bolts.
Re: Cork or Rubber? Tranny pan gasket... [Re: Reggie] #733629
06/26/10 12:38 AM
06/26/10 12:38 AM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
One of the best things I ever did. I love mine. It is a slightly different shape than a 727 pan from Mopar (old, or even their deep pan -- P3690730AB) but it seals and seals well. I agree with the torque issue too. I think the book calls for something like 150inlbs which is too much for cork too. I went to around 1/2 that.
Re: Cork or Rubber? Tranny pan gasket... [Re: dOrk !] #733630
06/26/10 01:59 AM
06/26/10 01:59 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I just rebuilt a GM (yeah I know ) but I re-used a rubber one that we had put on several weeks earlier when we thought it might just need a fluid and filter change. I got a new on in the kit but it was cork and as simply a personal choice, I'm not fond of cork. Anyway, point is, I just used a little film of white grease but no sealer. I go just snug on all bolts and another wrist twist (1/4 to 1/3 turn?) Been two weeks now and no leaks. If you can see the gasket compress and squish out any, you've over tightened.
Re: Cork or Rubber? Tranny pan gasket... [Re: Scott Carl] #733631
06/26/10 08:14 AM
06/26/10 08:14 AM
scratchnfotraction Offline
x2..x3...x4 on the newer pan gasket from the dealer
well worth the $
just dont over torque the pan bolts,the gasket does not crush and you can strip the threds very ez
if you do pull some threds out..you can usally get by with a longer bolt as the newer gasket is thicker
had mine 5 yrs now and on/off about 8x so far and still no leak at the pan rail
now the shift selector seal is another thing though
Re: Cork or Rubber? Tranny pan gasket... [Re: broncobra] #733632
06/27/10 12:19 PM
06/27/10 12:19 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I agee i just did my pan and used Indian head and a rubber gasket fixed the prblem.
Re: Cork or Rubber? Tranny pan gasket... [Re: moparsquid] #733633
06/27/10 12:26 PM
06/27/10 12:26 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Great stuff till you want to take it apart for a trans service. Have fun.
The new ribbed gaskets seal with no added sealer and are reusable.
Re: Cork or Rubber? Tranny pan gasket... [Re: MoparforLife] #733634
06/27/10 12:29 PM
06/27/10 12:29 PM
I've always 3m adhesive a cork gasket [after it relaxes] to the tranny pan and then bolt it up, no sealer in the trans side.
the 3m works great.
mainly you need a pan that has not been torq'd to death in the past.
Re: Cork or Rubber? Tranny pan gasket... #733635
06/27/10 12:50 PM
06/27/10 12:50 PM
x2
wait till you remove the indian gasket sealer for the next service
dont get me wrong..I use it and it is good stuff
i am just picky were I use it and it wont be coming off any time soon
that dealer gasket is the way to go..even on an over torqued warped pan..like mine
Re: Cork or Rubber? Tranny pan gasket... [Re: cuda_tim] #733636
06/27/10 02:24 PM
06/27/10 02:24 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
One more vote for the later model 46RE nylon gasket.
Reused mine after a nice trans fluid shower; no leaks, no problems.
Re: Cork or Rubber? Tranny pan gasket... [Re: MoparMarq] #733637
06/27/10 02:33 PM
06/27/10 02:33 PM
BDW Online content
BDW  Online Content
Either will work.
I'd take a good look at the entire area, I replaced my pan gasket 3 times. Finally found out there were 3 other leaks making it look like the pan gasket was the problem.
Re: Cork or Rubber? Tranny pan gasket... [Re: cuda_tim] #733638
06/27/10 03:59 PM
06/27/10 03:59 PM
Under My Car
Mopar_Country Offline
Under My Car
Make sure your pan is flat on the mating area. A lot of the time you will see that in the bolt hole area that they are bowl shaped, this is from over tightening. Check with a straight edge on the surface that mates to the housing and see if everything is flush. If not you can work the bolt holes in the opposite direction to get a good seal on install.
___________________________________________
2003 Dodge Ram 4x4 Hemi
2002 Dodge Ram Van
1995 Dodge Ram 4x4 V-10
1976 Jeep Cherokee
1974 Dart Sport
Re: Cork or Rubber? Tranny pan gasket... [Re: Mopar_Country] #733639
06/27/10 04:28 PM
06/27/10 04:28 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
1st get the reusable gasket best gasket you will ever buy 2nd if installed correctly no gasket needs any sealer at all we use the fiber gaskets at work I use no sealer and have no problems.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Cork or Rubber? Tranny pan gasket.. STILL LEAKS [Re: dusturbd340W5] #733640
09/04/10 12:52 PM
09/04/10 12:52 PM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Ok, since I posted last, I've had several gaskets on the tranny pan and it is still leaking...
I even got the one from the Chrysler dealer, and that one leaked also.
I also checked the flatness of the pan, it is fine. It is a deep pan.
The good thing is that I'm getting pretty good at dropping it. Luckily, it has a plug for drainage.
Ok, I'm beginning to think that perhaps it is leaking at the filler tube. I'm going to check that today.
But here is my question...
It only appears to leak when it is sitting (I know, otherwise I wouldn't notice it...duh!).
But I'm wondering if perhaps I'm overfilling it. The filler tube is NOT original. Does the fluid sitting in the pan normally lie ABOVE the seal between the pan and tranny? That is, perhaps when the car is sitting the fluid is supposed to be below the pan lip.
Anyone??
Re: Cork or Rubber? Tranny pan gasket.. STILL LEAKS [Re: cuda_tim] #733641
09/04/10 01:11 PM
09/04/10 01:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
fluid level is above the pan and you get converter drainback raising the fluid level as it sits.
Re: Cork or Rubber? Tranny pan gasket.. STILL LEAKS [Re: stumpy] #733642
09/04/10 01:29 PM
09/04/10 01:29 PM
Kirkland, Washington
Pacnorthcuda Offline
Many a pan gasket has been blamed for leaks that actually come from:
The selector shaft seal
The Fill-tube/O-ring
The reverse-shaft at the rear of the pan area, just above the pan rail
