Cork or Rubber? Tranny pan gasket...
#733623
06/25/10 10:20 PM
06/25/10 10:20 PM
Posts: 589 Waynesboro, PA
cuda_tim
Waynesboro, PA
Ok, I need to change the gasket on my 727 transmission pan. I used cork before, with some sort of blue RTV. I'm not sure that it ever stopped leaking! A dribble here & a dribble there. What do you suggest? I have a rubber gasket. But I'm used to cork. If I use the rubber gasket, what RTV should I use? I'm temped to use cork again, but with Permatex 2. Putting the gasket on the pan & letting it dry overnight. Then applying the same sealant with a dab on each screw... Any help would be greatly appreciated. Thanks! Tim...
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: Cork or Rubber? Tranny pan gasket...
[Re: 71autoxr]
#733628
06/26/10 12:24 AM
06/26/10 12:24 AM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
As long as the pan-rail is straight and flat ...and you do NOT over-torque the bolts .... ......ANY gaskets will work. I have a cork one on my 62 since the late-70's ... on and off maybe 8 or so times .....NO problem. And NOTE ... if you are chancing STRIPPING the threads in the case by OVERtightening ... you are using about FIVE TIMES ++ ... tooooo much torque on these bolts.
[Re: Reggie]
#733629
06/26/10 12:38 AM
06/26/10 12:38 AM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
Go to a Dodge/Chrysler dealer and get the newer style reuseable pan gasket. The number for the 727 (or A-518/46RH/46RE) is: 2464324AC. It is hard nylon over steel with molded in double sealing beads. Be careful not to overtorque it, or you can strip the case threads because it doesn't compress the same as a cork or rubber gasket.
One of the best things I ever did. I love mine. It is a slightly different shape than a 727 pan from Mopar (old, or even their deep pan -- P3690730AB) but it seals and seals well. I agree with the torque issue too. I think the book calls for something like 150inlbs which is too much for cork too. I went to around 1/2 that.
[Re: dOc !]
#733630
06/26/10 01:59 AM
06/26/10 01:59 AM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I just rebuilt a GM (yeah I know ) but I re-used a rubber one that we had put on several weeks earlier when we thought it might just need a fluid and filter change. I got a new on in the kit but it was cork and as simply a personal choice, I'm not fond of cork. Anyway, point is, I just used a little film of white grease but no sealer. I go just snug on all bolts and another wrist twist (1/4 to 1/3 turn?) Been two weeks now and no leaks. If you can see the gasket compress and squish out any, you've over tightened.
[Re: Scott Carl]
#733631
06/26/10 08:14 AM
06/26/10 08:14 AM
Posts: 15,487 Florida
scratchnfotraction
x2..x3...x4 on the newer pan gasket from the dealer well worth the $ just dont over torque the pan bolts,the gasket does not crush and you can strip the threds very ez if you do pull some threds out..you can usally get by with a longer bolt as the newer gasket is thicker had mine 5 yrs now and on/off about 8x so far and still no leak at the pan rail now the shift selector seal is another thing though
[Re: broncobra]
#733632
06/27/10 12:19 PM
06/27/10 12:19 PM
Posts: 1,107 Spring Valley ,Ca.
moparsquid
Spring Valley ,Ca.
Don't use rtv. Use Indian shellac or some thing else, or get one of those rubber/steel insert gaskets. RTV can get small blobs gunked up into everything, use a painted on type sealer.
I agee i just did my pan and used Indian head and a rubber gasket fixed the prblem.
[Re: moparsquid]
#733633
06/27/10 12:26 PM
06/27/10 12:26 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Great stuff till you want to take it apart for a trans service. Have fun. The new ribbed gaskets seal with no added sealer and are reusable.
[Re: MoparforLife]
#733634
06/27/10 12:29 PM
06/27/10 12:29 PM
I've always 3m adhesive a cork gasket [after it relaxes] to the tranny pan and then bolt it up, no sealer in the trans side. the 3m works great. mainly you need a pan that has not been torq'd to death in the past.
#733635
06/27/10 12:50 PM
06/27/10 12:50 PM
scratchnfotraction
x2 wait till you remove the indian gasket sealer for the next service dont get me wrong..I use it and it is good stuff i am just picky were I use it and it wont be coming off any time soon that dealer gasket is the way to go..even on an over torqued warped pan..like mine
[Re: cuda_tim]
#733638
06/27/10 03:59 PM
06/27/10 03:59 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
Make sure your pan is flat on the mating area. A lot of the time you will see that in the bolt hole area that they are bowl shaped, this is from over tightening. Check with a straight edge on the surface that mates to the housing and see if everything is flush. If not you can work the bolt holes in the opposite direction to get a good seal on install.
___________________________________________ 2003 Dodge Ram 4x4 Hemi 2002 Dodge Ram Van 1995 Dodge Ram 4x4 V-10 1976 Jeep Cherokee 1974 Dart Sport
[Re: Mopar_Country]
#733639
06/27/10 04:28 PM
06/27/10 04:28 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
1st get the reusable gasket best gasket you will ever buy 2nd if installed correctly no gasket needs any sealer at all we use the fiber gaskets at work I use no sealer and have no problems.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Cork or Rubber? Tranny pan gasket.. STILL LEAKS
[Re: dusturbd340W5]
#733640
09/04/10 12:52 PM
09/04/10 12:52 PM
cuda_tim
Waynesboro, PA
Ok, since I posted last, I've had several gaskets on the tranny pan and it is still leaking... I even got the one from the Chrysler dealer, and that one leaked also. I also checked the flatness of the pan, it is fine. It is a deep pan. The good thing is that I'm getting pretty good at dropping it. Luckily, it has a plug for drainage. Ok, I'm beginning to think that perhaps it is leaking at the filler tube. I'm going to check that today. But here is my question... It only appears to leak when it is sitting (I know, otherwise I wouldn't notice it...duh!). But I'm wondering if perhaps I'm overfilling it. The filler tube is NOT original. Does the fluid sitting in the pan normally lie ABOVE the seal between the pan and tranny? That is, perhaps when the car is sitting the fluid is supposed to be below the pan lip. Anyone??
