Speedo cable broke any ideas #73328
06/13/08 08:33 PM
06/13/08 08:33 PM
Niles , Ohio
therocks Offline OP
therocks  Offline OP
Niles , Ohio
Broke the cable in the speedo wed night.I guess it didnt like the 100 mph blast.It was only 43 year old.Any ideas to get it out of the sheath.It broke by the head of the speed and the 65 you just dont unscrew the other end from the trans.I just dont want to lose all my gear grease pulling the trans end.Ill eithe get a universal at work or my kid has his old one from his 62.I might even have a new inside piece at the other garage from the 65 Belvedere I parted.Rocky
Chrysler Firepower
Re: Speedo cable broke any ideas [Re: therocks] #73329
06/13/08 09:14 PM
06/13/08 09:14 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Autozone etc sell a replacement cable assembly well under $20.00
Pioneer part number CA-3004 $10.99
Re: Speedo cable broke any ideas [Re: 69DartGT] #73330
06/13/08 09:46 PM
06/13/08 09:46 PM
Niles , Ohio
therocks Offline OP
therocks  Offline OP
Niles , Ohio
Not worried about the cable.My kid works at AZ and our shop is right next to them.My problem is getting the broken piece out of the outer cable.I cant see it or id reach in with my tiny needle noise pliers.Ill just replace the inner as 65 cables are totally different than later ones.You have to pull the whole speed gear and all the 4 speed grease comes pouring out.Ill do it if I have to.Rocky
Chrysler Firepower
Re: Speedo cable broke any ideas [Re: therocks] #73331
06/13/08 09:52 PM
06/13/08 09:52 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Just unscrew the nut which retains the speedo cable to the pinion adapter housing in the trans. There should not be any fluid getting past the seal on the speedo pinions drive gear, so no fluid should leak out.
Re: Speedo cable broke any ideas [Re: In_The_Pink] #73332
06/13/08 10:00 PM
06/13/08 10:00 PM
Niles , Ohio
therocks Offline OP
therocks  Offline OP
Niles , Ohio
I guess you never worked on an early Mopar.The gear is attached to the outer cable and it goes in the trans.Its not a late cable.Ive had it in and out since 69 when i got the car.Just dont want to have to refill the 4 speed. Rocky
Chrysler Firepower
Re: Speedo cable broke any ideas [Re: therocks] #73333
06/14/08 04:31 AM
06/14/08 04:31 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Rocky,
You're dreaming!! You really know you can't do that without dumping the lube, I know you do. Just don't make too big a mess - but at least it's a 4 gear so you can drain it easily first.
Happy puddles,
Mike
Re: Speedo cable broke any ideas [Re: 1E2C] #73334
06/14/08 06:14 AM
06/14/08 06:14 AM
Niles , Ohio
therocks Offline OP
therocks  Offline OP
Niles , Ohio
Yeah I guess i am.Just hoped I could pull it out the speedo end.One day Ill put the late model trans in it.Well guess I better buy some gear oil also.Cheap factory parts only last 43 years lol.Rocky
Chrysler Firepower
Re: Speedo cable broke any ideas [Re: therocks] #73335
06/14/08 10:41 AM
06/14/08 10:41 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Was the cable binding? If so, I would replace both pieces. Mike
Re: Speedo cable broke any ideas [Re: therocks] #73336
06/14/08 12:58 PM
06/14/08 12:58 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Can you raise the rear of the car up fairly high so the lube runs to the front of the trans?
Sheldon
Re: Speedo cable broke any ideas [Re: RUNCHARGER] #73337
06/15/08 08:31 AM
06/15/08 08:31 AM
Niles , Ohio
therocks Offline OP
therocks  Offline OP
Niles , Ohio
Just got a few qts of gear oil.Ill pull the gear today as I cant get it out up top.Ill probally lose 1/2 when I pull iy.My cable had a kink for year so I dont feel bad that it broke.My kids drive cable is new so Ill install it.Rocky
Chrysler Firepower
