Not worried about the cable.My kid works at AZ and our shop is right next to them.My problem is getting the broken piece out of the outer cable.I cant see it or id reach in with my tiny needle noise pliers.Ill just replace the inner as 65 cables are totally different than later ones.You have to pull the whole speed gear and all the 4 speed grease comes pouring out.Ill do it if I have to.Rocky
Chrysler Firepower
