What waste gate?? #733223
06/25/10 03:39 AM
06/25/10 03:39 AM
Iowa
76dodgeboy Offline OP
Iowa
Whats waste gate should I get? Stock 318 or slant six. Most likely the 318 First. I have a Holset H1E and an intercooler and very little piping. What else will I need. Waste gate, bov, Blow through carb What carb is recomended aswell
Re: What waste gate?? [Re: 76dodgeboy] #733224
06/25/10 08:27 AM
06/25/10 08:27 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Depending on the amount of boost you might get by w/ just a POV. I ran 6psi on a S/C 440 and used a POV for a Audi turbo. As for a crab call somebody like Scott at SDCE or the guy at ExtremeAir. Both will help you get it right.
Coming soon!!!!
Re: What waste gate?? [Re: Mr.Yuck] #733225
06/27/10 12:12 PM
06/27/10 12:12 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
38mm is fine...that should be on the flange on the kit i sold you...40-50mm is fine on the bov...you can get them cheap from vs racing on turbomustangs...just the x02 brand you dont need high dollar stuff
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: What waste gate?? [Re: dodge turbo] #733226
06/27/10 03:37 PM
06/27/10 03:37 PM
Iowa
Iowa
Where exactly does the waste gate go. Just before the turbo or after? I was going to sell most of it but changed my mind. I want a turbocharged truck. Itll all be pretty mild to start with. I have an 80 St Regis copcar 318/4bbl that I plan to use.
Re: What waste gate?? [Re: 76dodgeboy] #733227
06/27/10 05:04 PM
06/27/10 05:04 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Wastegate is after the turbo. It diverts the air from the pressure side to the exhaust for overboost conditions such as limiting boost and between shifts among a couple others.
Damon
Re: What waste gate?? [Re: mopardamo] #733228
06/27/10 05:31 PM
06/27/10 05:31 PM
Iowa
Iowa
Anyone have pics? Im still fairly new to turbos and want to get it rite when I start. Thanks
Re: What waste gate?? [Re: mopardamo] #733229
06/27/10 06:22 PM
06/27/10 06:22 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Hello,
Damon
The wastegate needs to go before the turbo! It diverts exhaust gas away from the turbine to prevent overboosting during engine acceleration.
I believe Damon meant to say a "blow off valve or BOV" (not a wastegate) goes in the charge pipe to limit compressor surge when closing the throttle blades as can occur during shifts.
Here's a pic of a wastegate flange location on an import engine. Same concept on your car, somewhere before the turbine side of the turbo.
Re: What waste gate?? [Re: 1badx] #733230
06/27/10 06:42 PM
06/27/10 06:42 PM
Iowa
Iowa
Hello,
Damon
I was alittle confused there. I knew the bov was after the turbo. Should the BOV be close to the carb/throtle body or anywhere after the intercooler Thanks
Re: What waste gate?? [Re: 76dodgeboy] #733231
06/27/10 08:04 PM
06/27/10 08:04 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
The wastegate is before the turbo, and likes to be oriented in a manner that the exhaust can run right into the gate on its way to the...see the picture for explanation
The bov can go just before the carb/throttle body and is always closed and uses vacuum to open it
a lot of guys put the bov before the intercooler, others do it after, myself there is no intercooler to worry about yet
Re: What waste gate?? [Re: joshking440] #733232
06/27/10 08:10 PM
06/27/10 08:10 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
bov pic if you needed
Re: What waste gate?? [Re: joshking440] #733233
06/27/10 08:12 PM
06/27/10 08:12 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
I have my BOV after the intercooler. It is there for packaging reasons. Pretty much any wastegate would work with that combo. Ebay has cheap ones.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: What waste gate?? [Re: CW25] #733234
06/27/10 08:35 PM
06/27/10 08:35 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Like CW said, buy a cheap gate for your combo, it will work just fine. Try SS Autochrome or Ebay
Re: What waste gate?? [Re: 1badx] #733235
06/28/10 12:54 AM
06/28/10 12:54 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
If you have an intercooler BOV should be after it...
Re: What waste gate?? [Re: CokeBottleKid] #733236
06/28/10 07:57 PM
06/28/10 07:57 PM
dodge turbo Offline
dodge turbo  Offline
Why do people comment when they have no clue what they are talking about gets me for sure....
Wastegate is before the turbo and as close as you can get it to the turbo or merge area, it vents exhaust way from the turbo to get the boost you desire....BOV is before the carb or injection. i dont think it really matters if its before or after the intercooler, mine is after, close to the carb, and you should always have one. It prevents compressor surge which will damage a turbo. i have X02 wastegate (60mm)and Bov(50mm) and have less than 250 invested for both of them and they work awesome, they are HKS knockoffs and would recomment with any cheap knockoff to take it apart and clean lube it well. i got both of them from Vsracing.net a site sponsor on turbomustangs.com
Re: What waste gate?? [Re: mopardamo] #733237
06/28/10 09:34 PM
06/28/10 09:34 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Hello,
Damon
pay no attention to any advice from this guy
Re: What waste gate?? [Re: joshking440] #733238
06/28/10 11:52 PM
06/28/10 11:52 PM
Iowa
Iowa
I was pretty sure its before. I ment where or how close to before the turbo.
Re: What waste gate?? [Re: 76dodgeboy] #733239
06/29/10 12:28 AM
06/29/10 12:28 AM
CW25 Offline
CW25  Offline
Like dodge turbo said after the merge before the turbo. Mine is about 3" from the turbo just make sure you vent both sides of the engine not just one.
Re: What waste gate?? [Re: dodge turbo] #733240
06/30/10 01:54 AM
06/30/10 01:54 AM
Iowa
Iowa
What Flang? The pic of it onstalled on your motor had a spacer between the manifold and the turbo with the bov but I dont believe I got that? Circled
Re: What waste gate?? [Re: 76dodgeboy] #733241
06/30/10 02:06 AM
06/30/10 02:06 AM
Iowa
Iowa
Would this work for the BOV
http://cgi.ebay.com/ebaymotors/ws/eBayIS...e=STRK:MEWAX:IT
Im going to checkout the tiurbo stang forum aswell
Re: What waste gate?? [Re: 76dodgeboy] #733242
06/30/10 03:36 PM
06/30/10 03:36 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That will work. It will also be most annoying. See the trumpets? They'll hoot and holler every time you let off the throttle.
Ricers flock to them. It's like a fart pipe muffler for the intake.
Find one without a trumpet and it'll be much easier to live with.
Factory turbo cars usually route the BOV back into the air filter to silence them.
On the wastegate, think of it as a short cut. When boost gets too high they open up and let exhaust sneak around the turbo and straight into the exhaust pipe. Again, smoother is better on the plumbing.
- Stu Harmon
