Re: What waste gate??
[Re: Mr.Yuck]
#733225
06/27/10 12:12 PM
06/27/10 12:12 PM
Posts: 468 Dirty Dena, Maryland
dodge turbo
38mm is fine...that should be on the flange on the kit i sold you...40-50mm is fine on the bov...you can get them cheap from vs racing on turbomustangs...just the x02 brand you dont need high dollar stuff
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
[Re: mopardamo]
#733229
06/27/10 06:22 PM
06/27/10 06:22 PM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
Hello,
Wastegate is after the turbo. It diverts the air from the pressure side to the exhaust for overboost conditions such as limiting boost and between shifts among a couple others.
Damon
The wastegate needs to go before the turbo! It diverts exhaust gas away from the turbine to prevent overboosting during engine acceleration.
I believe Damon meant to say a "blow off valve or BOV" (not a wastegate) goes in the charge pipe to limit compressor surge when closing the throttle blades as can occur during shifts.
Here's a pic of a wastegate flange location on an import engine. Same concept on your car, somewhere before the turbine side of the turbo.
[Re: 1badx]
#733230
06/27/10 06:42 PM
06/27/10 06:42 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Hello,
Damon
I was alittle confused there. I knew the bov was after the turbo. Should the BOV be close to the carb/throtle body or anywhere after the intercooler Thanks
[Re: 76dodgeboy]
#733231
06/27/10 08:04 PM
06/27/10 08:04 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
The wastegate is before the turbo, and likes to be oriented in a manner that the exhaust can run right into the gate on its way to the...see the picture for explanation
The bov can go just before the carb/throttle body and is always closed and uses vacuum to open it
a lot of guys put the bov before the intercooler, others do it after, myself there is no intercooler to worry about yet
[Re: CokeBottleKid]
#733236
06/28/10 07:57 PM
06/28/10 07:57 PM
dodge turbo
Why do people comment when they have no clue what they are talking about gets me for sure....
Wastegate is before the turbo and as close as you can get it to the turbo or merge area, it vents exhaust way from the turbo to get the boost you desire....BOV is before the carb or injection. i dont think it really matters if its before or after the intercooler, mine is after, close to the carb, and you should always have one. It prevents compressor surge which will damage a turbo. i have X02 wastegate (60mm)and Bov(50mm) and have less than 250 invested for both of them and they work awesome, they are HKS knockoffs and would recomment with any cheap knockoff to take it apart and clean lube it well. i got both of them from Vsracing.net a site sponsor on turbomustangs.com
[Re: mopardamo]
#733237
06/28/10 09:34 PM
06/28/10 09:34 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Hello,
Damon
pay no attention to any advice from this guy
[Re: 76dodgeboy]
#733239
06/29/10 12:28 AM
06/29/10 12:28 AM
Posts: 350 Grande Prairie, Alberta, Can.
CW25
I was pretty sure its before. I ment where or how close to before the turbo.
Like dodge turbo said after the merge before the turbo. Mine is about 3" from the turbo just make sure you vent both sides of the engine not just one.
[Re: 76dodgeboy]
#733242
06/30/10 03:36 PM
06/30/10 03:36 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
That will work. It will also be most annoying. See the trumpets? They'll hoot and holler every time you let off the throttle. Ricers flock to them. It's like a fart pipe muffler for the intake. Find one without a trumpet and it'll be much easier to live with.
Factory turbo cars usually route the BOV back into the air filter to silence them.
On the wastegate, think of it as a short cut. When boost gets too high they open up and let exhaust sneak around the turbo and straight into the exhaust pipe. Again, smoother is better on the plumbing.
