Gibbs brand penetrant? LOOKS like great stuff #731612
06/22/10 09:12 PM
06/22/10 09:12 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Just ran across this website whill looking around at different styles of vintage wheels for old muscle cars. The guy has a webpage devoted to this stuff.
http://www.roadsters.com/gibbs/
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Gibbs brand penetrant? LOOKS like great stuff [Re: 71TA] #731613
06/22/10 10:18 PM
06/22/10 10:18 PM
Keizer, Oregon
Dadrules Offline
Dadrules  Offline
Keizer, Oregon
wow! snake oil or ?? i'm going to buy a couple of cans of this to try. I do a fair amount of shooting in addition to throwing time and money at our Barracuda and always looking for a better lubricant for semi-autos.
Re: Gibbs brand penetrant? LOOKS like great stuff [Re: 71TA] #731614
06/22/10 10:29 PM
06/22/10 10:29 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I found that page the other day when look up info on some wheels I have. Seems like a legit guy as he's a regular on some old hot rod boards.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Gibbs brand penetrant? LOOKS like great stuff [Re: Dadrules] #731615
06/22/10 10:37 PM
06/22/10 10:37 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
I thought the same thing. I may break down and pic up a couple cans. From his write up I may never need any more than 2 cans
Re: Gibbs brand penetrant? LOOKS like great stuff [Re: 71TA] #731616
06/23/10 12:35 AM
06/23/10 12:35 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Save your time and money and buy a can of protectant from the hardware store...even WD40 will do the same thing- penetrate and displace moisture to prevent corrosion.
I bead blasted then sprayed these with the attached product and have had zero corrosion in two years of sitting on a concrete floor:
Re: Gibbs brand penetrant? LOOKS like great stuff [Re: In_The_Pink] #731617
06/23/10 12:48 AM
06/23/10 12:48 AM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
They say you can paint over it. FEEL LUCKY anyone?
Re: Gibbs brand penetrant? LOOKS like great stuff [Re: Y3 70 BEE] #731618
06/23/10 12:56 AM
06/23/10 12:56 AM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
And that black and white pic of the guy and car looks new.
Re: Gibbs brand penetrant? LOOKS like great stuff [Re: Y3 70 BEE] #731619
06/27/10 09:29 AM
06/27/10 09:29 AM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
Also states on that web page;
Painting over Gibbs Brand
The label on a can of Gibbs Brand says that "you can paint right over it". However, common sense will tell you not to paint over an oily surface that isn't clean.
To paint metal that has been treated with Gibbs Brand, simply begin by wiping it down with whatever surface cleaner is recommended by the manufacturer of the particular paint system that you are using, and proceed as you normally would.
Due to the tremendous variety of ingredients that are used in paints, it is not possible to be absolutely certain that Gibbs Brand is compatible with every paint on the market. However, we are not aware of any compatibility issues with any particular paint
Re: Gibbs brand penetrant? LOOKS like great stuff [Re: Spike] #731620
07/04/10 08:40 AM
07/04/10 08:40 AM
SE Pa.
LimeliteAero Online content
LimeliteAero  Online Content
SE Pa.
Ive been using nothing but Gibbs oil for about 20 years.
Its the best penatrating oil Ive ever used.(not saying the best out there only the best Ive used.) It makes easy work of some of the nasty rusted stuck nuts and bolts.
I first stumbled across it at Carlisle but now its not so easy to purchase.
