Re: Gibbs brand penetrant? LOOKS like great stuff
[Re: 71TA]
#731614
06/22/10 10:29 PM
06/22/10 10:29 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I found that page the other day when look up info on some wheels I have. Seems like a legit guy as he's a regular on some old hot rod boards.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Dadrules]
#731615
06/22/10 10:37 PM
06/22/10 10:37 PM
Posts: 12,432 Warren, MI
71TA
Warren, MI
wow! snake oil or ?? i'm going to buy a couple of cans of this to try. I do a fair amount of shooting in addition to throwing time and money at our Barracuda and always looking for a better lubricant for semi-autos.
I thought the same thing. I may break down and pic up a couple cans. From his write up I may never need any more than 2 cans
[Re: Y3 70 BEE]
#731619
06/27/10 09:29 AM
06/27/10 09:29 AM
Posts: 4,866 N. of 8mile, S. of heaven
Spike
Go Blue!!
Go Blue!!
They say you can paint over it. FEEL LUCKY anyone?
Also states on that web page;
Painting over Gibbs Brand The label on a can of Gibbs Brand says that "you can paint right over it". However, common sense will tell you not to paint over an oily surface that isn't clean.
To paint metal that has been treated with Gibbs Brand, simply begin by wiping it down with whatever surface cleaner is recommended by the manufacturer of the particular paint system that you are using, and proceed as you normally would.
Due to the tremendous variety of ingredients that are used in paints, it is not possible to be absolutely certain that Gibbs Brand is compatible with every paint on the market. However, we are not aware of any compatibility issues with any particular paint
[Re: Spike]
#731620
07/04/10 08:40 AM
07/04/10 08:40 AM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
Ive been using nothing but Gibbs oil for about 20 years.
Its the best penatrating oil Ive ever used.(not saying the best out there only the best Ive used.) It makes easy work of some of the nasty rusted stuck nuts and bolts. I first stumbled across it at Carlisle but now its not so easy to purchase.
