Heater Fuse Getting Hot??? #726808
06/17/10 04:20 PM
06/17/10 04:20 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
My Heater Fuse on my Dart gets real hot after one Min. & you can tell its been getting too hot! What do you guys think would be makeing it do that???
Re: Heater Fuse Getting Hot??? [Re: Hoop] #726809
06/17/10 04:24 PM
06/17/10 04:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Heater motor or blower motor resistor going bad.
Re: Heater Fuse Getting Hot??? [Re: stumpy] #726810
06/17/10 05:20 PM
06/17/10 05:20 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I'm thinking resistor too, So Would a 71 dart heater blower resistor work on a 72 dart ???
Re: Heater Fuse Getting Hot??? [Re: Hoop] #726811
06/17/10 05:26 PM
06/17/10 05:26 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
If it still does it on high speed it is not the resistor, high bypasses the resistor
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Heater Fuse Getting Hot??? [Re: HealthServices] #726812
06/17/10 05:40 PM
06/17/10 05:40 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
There is no way a fuse should be getting hot. They are rated by the amps the wires/components can handle (actually the fuse is a lower rating), so the only thing that can cause a fuse to get hot is exactly what I'm seeing in your picture, CORROSION. The fuses are not making good contact in the holders due to rust.
Re: Heater Fuse Getting Hot??? [Re: Jim_Lusk] #726813
06/17/10 05:45 PM
06/17/10 05:45 PM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Geeeez, no kidding, thats terrible! I would think the fuse would blow first. I'd hate to see what your bulkhead connector looks like. Looks like a fire waiting to happen!
Re: Heater Fuse Getting Hot??? [Re: stubbs300 ] #726814
06/17/10 05:50 PM
06/17/10 05:50 PM
scratchnfotraction Offline
on my 68 Dart the wiper pivot leaked water and driped right into the fuse box and stayed rust
those need sand blasted and some die-electric grease
sure wont hurt to change that fuse thats all rusted on the inside of the glass
Re: Heater Fuse Getting Hot??? [Re: stubbs300 ] #726815
06/17/10 05:57 PM
06/17/10 05:57 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Nope, the rust is LIMITING current. The heat is caused by the extra resistance. Heat in Watts is I^2*R (as I recall). So, with a very low resistance, which fuses and wire are SUPPOSED to be, there won't be much heat, but start adding resistance (even though the current will go DOWN) and you start making heat.
Re: Heater Fuse Getting Hot??? [Re: Jim_Lusk] #726816
06/17/10 05:59 PM
06/17/10 05:59 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Jim is 100% correct.
I want my fair share
Re: Heater Fuse Getting Hot??? [Re: SomeCarGuy] #726817
06/17/10 06:37 PM
06/17/10 06:37 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
110%, I believe...
Re: Heater Fuse Getting Hot??? [Re: Hoop] #726818
06/17/10 08:28 PM
06/17/10 08:28 PM
Alberta
rustbuckett68 Offline
Alberta
Had a similar problem in my 79 B300. After replacing the blower motor and not fixing it, I got smart(?) and checked the wiring. There was a plug connector in between the switch gear and the motor that was corroded. Quick connector replace, works as new, and now I have a spare blower motor!!!
Re: Heater Fuse Getting Hot??? [Re: scratchnfotraction] #726819
06/21/10 03:40 PM
06/21/10 03:40 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
That is a new fuse, wear it got hot, it did that in one mouth!
Re: Heater Fuse Getting Hot??? [Re: HealthServices] #726820
06/21/10 03:51 PM
06/21/10 03:51 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
It douse it on all speeds, So I,ll tray to see if I can sand it down some how, see if that helps!
Re: Heater Fuse Getting Hot??? [Re: Hoop] #726821
06/21/10 04:02 PM
06/21/10 04:02 PM
wow looks like that in a month??
put on a jacket and ride with the heater off/windows up,IMHO
Re: Heater Fuse Getting Hot??? [Re: scratchnfotraction] #726822
06/21/10 06:14 PM
06/21/10 06:14 PM
Champlin Mn.
2
2DoorPost Offline
2DoorPost  Offline
Champlin Mn.
I have a van that was doing the same thing,the fuse got real hot then it would blow the fuse after 4-5 minutes.The blower motor needed oil,now it works great!
