Re: Heater Fuse Getting Hot???
[Re: Hoop]
#726811
06/17/10 05:26 PM
06/17/10 05:26 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
If it still does it on high speed it is not the resistor, high bypasses the resistor
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: Jim_Lusk]
#726813
06/17/10 05:45 PM
06/17/10 05:45 PM
Posts: 1,181 Lost in the ozone again
stubbs300
Vacation
Vacation
There is no way a fuse should be getting hot. They are rated by the amps the wires/components can handle (actually the fuse is a lower rating), so the only thing that can cause a fuse to get hot is exactly what I'm seeing in your picture, CORROSION. The fuses are not making good contact in the holders due to rust.
Geeeez, no kidding, thats terrible! I would think the fuse would blow first. I'd hate to see what your bulkhead connector looks like. Looks like a fire waiting to happen!
[Re: stubbs300 ]
#726815
06/17/10 05:57 PM
06/17/10 05:57 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Nope, the rust is LIMITING current. The heat is caused by the extra resistance. Heat in Watts is I^2*R (as I recall). So, with a very low resistance, which fuses and wire are SUPPOSED to be, there won't be much heat, but start adding resistance (even though the current will go DOWN) and you start making heat.
[Re: SomeCarGuy]
#726817
06/17/10 06:37 PM
06/17/10 06:37 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Jim is 100% correct.
110%, I believe...
[Re: scratchnfotraction]
#726819
06/21/10 03:40 PM
06/21/10 03:40 PM
Posts: 489 Partridge, KY
Hoop
Partridge, KY
on my 68 Dart the wiper pivot leaked water and driped right into the fuse box and stayed rust
those need sand blasted and some die-electric grease
sure wont hurt to change that fuse thats all rusted on the inside of the glass
That is a new fuse, wear it got hot, it did that in one mouth!
