440-externally balanced #725507
06/15/10 10:42 PM
06/15/10 10:42 PM
NC
Sixt8Chrgr Offline OP
NC
If I put an externally balanced 440 in my 68 Charger with a torque flight can I use the stock torque converter that came with the 68 original torque flight that is in the car?
I know I have to use an externally balanced flex plate but don't much from there. Dont much about automatics.
Thanks,
Re: 440-externally balanced [Re: Sixt8Chrgr] #725508
06/16/10 01:49 AM
06/16/10 01:49 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The external balance of the last years of the 440 needed both : The correct harmonic balancer AND weighted torque converter. Since you want to retain the older non weighted '68 converter, you have 2 options: You can have the correct weight balance added to your '68 converter OR get the B&M flexplate with the balance offset factored in.
I would have the converter modified. A trans shop can either do it or recommend a source. It can be done for less than $50.
Re: 440-externally balanced [Re: Kern Dog] #725509
06/16/10 07:01 AM
06/16/10 07:01 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use both and you willhave no problems at - been done a kazillion times.
Re: 440-externally balanced [Re: MoparforLife] #725510
06/16/10 07:39 AM
06/16/10 07:39 AM
NC
NC
I suppose another option would be to buy a new externally balanced torque converter?
I saw the flex plate on the B&M site.
Re: 440-externally balanced [Re: Sixt8Chrgr] #725511
06/16/10 07:39 AM
06/16/10 07:39 AM
an8sec70cuda Offline
Just get the B&M flexplate for the externally balanced 440 and be done with it. Then you're free to use whatever converter you want. Not to mention it's just a simple bolt in deal and easier than trying to find someone to weld on the weight in the correct spot on the converter.
B&M 10238 if you have a forged crank ext. balance 440
B&M 10237 if you have a cast crank ext. balance 440
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 440-externally balanced [Re: an8sec70cuda] #725512
06/16/10 07:46 AM
06/16/10 07:46 AM
NC
NC
Thanks Chip
Re: 440-externally balanced [Re: MoparforLife] #725513
06/16/10 09:11 AM
06/16/10 09:11 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Flex plate and torque converter?
Seems counter-intuitive.
Re: 440-externally balanced [Re: Commando1] #725514
06/17/10 12:21 PM
06/17/10 12:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you might want to read this AGAIN ...
