Just get the B&M flexplate for the externally balanced 440 and be done with it. Then you're free to use whatever converter you want. Not to mention it's just a simple bolt in deal and easier than trying to find someone to weld on the weight in the correct spot on the converter.
B&M 10238 if you have a forged crank ext. balance 440 B&M 10237 if you have a cast crank ext. balance 440
