904 transmission sound has me baffled
#724397
06/14/10 05:55 PM
06/14/10 05:55 PM
Posts: 22 southern california, usa
jjdirt
my 72 barracuda's 904 transmission is makeing a ticking noise when it is in gear. it a constant tick like if a bolt from the flex plate would hit the motor on rotation but it not that since i only hear the sound in gear yet the transmission seems to run fine. does any one have an idea of what it might be thanks
Re: 904 transmission sound has me baffled
[Re: jjdirt]
#724399
06/14/10 06:35 PM
06/14/10 06:35 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Don't rule out the flexplate area just because it only does it in gear, the converter load changes from Neutral to "in gear".
[Re: jjdirt]
#724401
06/15/10 05:43 AM
06/15/10 05:43 AM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
thanks i believe you are right since problem strated when i did a burnout with my 426 sb stroker thanks again
Did you build the 904 to handle that motor ?
