904 transmission sound has me baffled #724397
06/14/10 05:55 PM
06/14/10 05:55 PM
southern california, usa
jjdirt Offline OP
jjdirt  Offline OP
my 72 barracuda's 904 transmission is makeing a ticking noise when it is in gear. it a constant tick like if a bolt from the flex plate would hit the motor on rotation but it not that since i only hear the sound in gear yet the transmission seems to run fine. does any one have an idea of what it might be thanks
Re: 904 transmission sound has me baffled [Re: jjdirt] #724398
06/14/10 05:59 PM
06/14/10 05:59 PM
Under My Car
Mopar_Country Offline
Under My Car
Could it possibly be a slight exhaust leak your hearing? I have had cars in the past do that, at idle in park you could not hear it when you put it in gear it would drop the rpm's just enough to make it noticeable. Just a thought.
Re: 904 transmission sound has me baffled [Re: jjdirt] #724399
06/14/10 06:35 PM
06/14/10 06:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Don't rule out the flexplate area just because it only does it in gear, the converter load changes from Neutral to "in gear".
Re: 904 transmission sound has me baffled [Re: John_Kunkel] #724400
06/15/10 12:16 AM
06/15/10 12:16 AM
jjdirt Offline OP
jjdirt  Offline OP
thanks i believe you are right since problem strated when i did a burnout with my 426 sb stroker thanks again
Re: 904 transmission sound has me baffled [Re: jjdirt] #724401
06/15/10 05:43 AM
06/15/10 05:43 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Did you build the 904 to handle that motor ?
Re: 904 transmission sound has me baffled [Re: JohnRR] #724402
06/15/10 07:52 AM
06/15/10 07:52 AM
scratchnfotraction Offline
cracked flex plat
