Page 4 of 4 1 2 3 4
Re: E-85 or Race Fuel [Re: Fast Yeti] #721785
06/15/10 11:11 AM
06/15/10 11:11 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
My friend is running E-85 out of the pump in his low 9 sec twin turbo small block chev and just keeps bugging me to change to E-85. We have no race gas withing 100 miles and E-85 within 30 miles and it has a much better price tag. I have seen a couple cars run real crappy with there carbs converted to E-85 by a local person. Anyone use CSU for carb conversion? I run a pro comp 140 pump,this prob isnt going to cut it is it?
67' charger 499 RB 10.57 at 127
Re: E-85 or Race Fuel [Re: Fast Yeti] #721786
06/15/10 12:40 PM
06/15/10 12:40 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
For the most part - I like the prospects of E-85 and am considering using it for my current EFI project. HOWEVER keep in mind, NHRA considers E-85 as "alcohol". If running alcohol faster than 9.99 with a supercharger or turbo, a 3.2A/15 firesuit is required instead of a 3.2A/5 suit for race fuel in the same car.
Scott, what about NA combos?
N/A you are good with race fuel, E-85, or alcohol, to down to 7.50 with a 3.2A/5 suit, 3.3/1 gloves, and 3.3 neck collar. Don't even need shoes (assuming a .024 steel firewall and in a door car).
And I would suggest an "SA" rated helmet rather than a "M", as the SA has a fire retardant liner.
Scott
Re: E-85 or Race Fuel [Re: FlyFish] #721787
06/15/10 01:06 PM
06/15/10 01:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When running 2 fuel pumps, like 2 Holley black pumps, do you connect them in series (on one line) or have them each on their own dedicated fuel line?
I have 2 ports coming out of the fuel cell 1 going to
each pump then out of the pumps to a Y then forward
to the front with a #10 braided line
Re: E-85 or Race Fuel [Re: MR_P_BODY] #721788
06/15/10 02:40 PM
06/15/10 02:40 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Long ago I ran 2 Holley pumps, 1 to each fuel bowl. Seemed like a good idea till the pump feeding the front bowl expired after a burnout and I couldn't even keep it running long enough to stage the car.
Definitely run them into a Y.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: E-85 or Race Fuel [Re: Fast Yeti] #721789
06/15/10 08:00 PM
06/15/10 08:00 PM
sweden
street_dart Offline
street_dart  Offline
sweden
My motor made 780Hp on E-85 and 840Hp on VP109 unleded. Same dyno same day.
My friends cebby BB made 120 more Hp on VP109 compered to E-85.
This was with Garry Williams e-85 carbs and ordinary Holley Dominator gas carbs.
Do i need to say that i run VP109?
Dodge Dart-67 Dodge Custom Royal Lancer-55 Dodge Dakota 4.7 -05
Re: E-85 or Race Fuel [Re: street_dart] #721790
06/15/10 08:06 PM
06/15/10 08:06 PM
NC
440Jim Offline
440Jim  Offline
NC
Lots of things could have caused this result, but I am thinking those Garry Williams carbs are junk, not setup right for E85, IMO.
Re: E-85 or Race Fuel [Re: 440Jim] #721791
06/15/10 08:21 PM
06/15/10 08:21 PM
sweden
street_dart Offline
street_dart  Offline
sweden
The AFR(gas scale) was tested upp and down. I dont have any numbers here but i think it made the best @12.somthing on my motor and 34spark adv.
Some guys over here runing turbo motors now konverting from e-85 to race gas. They say that e-85 make more power than pump gas and that race gas make more power tan e-85.
Re: E-85 or Race Fuel [Re: street_dart] #721792
06/16/10 08:08 AM
06/16/10 08:08 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
You guys in Sweden don't know how to make MOONSHINE right!! You really need to get some made in the USA from the southern states.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: E-85 or Race Fuel [Re: 440Jim] #721793
06/16/10 09:46 AM
06/16/10 09:46 AM
MG, Brazil
v8punch Offline
v8punch  Offline
MG, Brazil
Braziliam ethanol (C2H6O) has 3.7% of water on it. It's corrosive...
It cost like u$2.2 to u$2.6/gallon, but 1/2 are duties
Re: E-85 or Race Fuel [Re: v8punch] #721794
06/16/10 09:27 PM
06/16/10 09:27 PM
NC
440Jim Offline
440Jim  Offline
NC
Thanks for the info.
If I understand it right, at 1.80 Brazilian Real per US Dollar, you pay about 4.00 Brazilian Real per gallon. And is that US gallons or Imperial gallons? As I recall, 1 Imperial gallon is 1.2 US gallons.
Yes, fuel taxes in the US are pretty low compared to many countries, except oil producer countries which sell gasoline to their citizens at less than production cost (govt subsidized by oil export sales).
Re: E-85 or Race Fuel [Re: 440Jim] #721795
06/20/10 11:42 AM
06/20/10 11:42 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Is it possible to purchase this e-85 fuel in 55-gal. drums from distributers? If so who sells it? Thaxx.
Re: E-85 or Race Fuel [Re: racerx] #721796
06/20/10 12:40 PM
06/20/10 12:40 PM
NC
440Jim Offline
440Jim  Offline
NC
This race fuel provider makes their own "race" blend of E-85, but it is much more expensive then the pump blend sold at gas stations.
http://www.rockettbrand.com/index.html
Check out the natiowide stations carrying E-85 at the pump so far (and growing).
http://www.e85refueling.com/
http://e85prices.com/
Re: E-85 or Race Fuel [Re: 440Jim] #721797
06/20/10 04:26 PM
06/20/10 04:26 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Cool Thaxxx 4 the link.
Page 4 of 4 1 2 3 4
