vin numbers #72102
06/12/08 03:00 PM
06/12/08 03:00 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
where else are vin numbers on a vehicle besides vin plate and rad support. I'm looking at a 67 GTX and the vin starts with RS23 but the rest of the car is suspect..the rad support number on this car is unreadable...Thanks in advance to all
Re: vin numbers [Re: terzmo] #72103
06/12/08 03:59 PM
06/12/08 03:59 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Try looking:
1. on the panel behind the rear bumper, below the trunk, toward the driver's side.
2. under the weather stripping, along the driver's side of the trunk, toward the front.
Re: vin numbers [Re: terzmo] #72104
06/12/08 06:07 PM
06/12/08 06:07 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The VIN will NOT appear anywhere else on that car. The stamped number on the rad support, trunk lip, AND fender tag is the Shipping Order Number. You can only match the two numbers with the Broadcast Sheet.
Re: vin numbers [Re: Jim_Lusk] #72105
06/12/08 08:23 PM
06/12/08 08:23 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Oops, sorry, Jim_Lusk is right (it's been a while since I went thru this). When I went to AAA to register my Coronet, I was lucky to have the Broadcast Sheet that showed the correlation between the VIN and the S.O. Number. Multiple VINs didn't begin until 1969.
Re: vin numbers [Re: Jim_Lusk] #72106
06/12/08 09:09 PM
06/12/08 09:09 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
so...this car may be a satellite or belvedere with a gtx vin tag replacement......thanks Guys..appreciate the help
Re: vin numbers [Re: terzmo] #72107
06/12/08 09:59 PM
06/12/08 09:59 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Do you have a Broadcast Sheet? And is there a data plate (under the hood, driver's side) on the car? The S.O. Number that is stamped in multiple places on the car should also be on the data plate. Do any of the numbers match at all?
Re: vin numbers [Re: Fab64] #72108
06/12/08 10:57 PM
06/12/08 10:57 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The VIN number is not on a '67 fender tag, BUT the car line is. For this car the bottom line on the left side should be stamped RS23 indicating a GTX. If it has this it can't be a Satellite (RP) or a Belvedere (RH for the II)
Re: vin numbers [Re: 6PakBee] #72109
06/12/08 11:14 PM
06/12/08 11:14 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I was thinking the SO number was behind the bumper on a '67 B body and not on the trunk rail. Or was that 66 only?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: vin numbers [Re: Jim_Lusk] #72110
06/12/08 11:51 PM
06/12/08 11:51 PM
What about on a 1970? I thought I remember seeing that on my radiator support, the numbers there match the serial #'s from my VIN (also on my Fender tag and dashboard tag) ??
Or am I remembering this incorrectly?
Re: vin numbers #72111
06/13/08 12:30 AM
06/13/08 12:30 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
On a 70, the VIN should be stamped on the support. Mopar started stamping the VIN on the raditor support with the '69 model year.
Seeking:
Re: vin numbers [Re: 69CoronetRT] #72112
06/13/08 01:32 AM
06/13/08 01:32 AM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I thought it was in both places, but I must have remembered wrong. I just went out and checked my '66 Coronet - it's on the panel behind the bumper, but I couldn't find it on the trunk rail. On my '67 Barracuda, it is on the trunk rail (I never checked behind the bumper, and I can't get to it right now).
Re: vin numbers [Re: Fab64] #72113
06/13/08 08:43 PM
06/13/08 08:43 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
no data plate or fendertag
