Re: vin numbers
[Re: terzmo]
#72104
06/12/08 06:07 PM
06/12/08 06:07 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
where else are vin numbers on a vehicle besides vin plate and rad support. I'm looking at a 67 GTX and the vin starts with RS23 but the rest of the car is suspect..the rad support number on this car is unreadable...Thanks in advance to all
The VIN will NOT appear anywhere else on that car. The stamped number on the rad support, trunk lip, AND fender tag is the Shipping Order Number. You can only match the two numbers with the Broadcast Sheet.
Re: vin numbers
[Re: Fab64]
#72108
06/12/08 10:57 PM
06/12/08 10:57 PM
Posts: 10,698 North Dakota
6PakBee
North Dakota
The VIN number is not on a '67 fender tag, BUT the car line is. For this car the bottom line on the left side should be stamped RS23 indicating a GTX. If it has this it can't be a Satellite (RP) or a Belvedere (RH for the II)
Re: vin numbers
[Re: 6PakBee]
#72109
06/12/08 11:14 PM
06/12/08 11:14 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
I was thinking the SO number was behind the bumper on a '67 B body and not on the trunk rail. Or was that 66 only?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
Re: vin numbers
[Re: Jim_Lusk]
#72110
06/12/08 11:51 PM
06/12/08 11:51 PM
What about on a 1970? I thought I remember seeing that on my radiator support, the numbers there match the serial #'s from my VIN (also on my Fender tag and dashboard tag) ??
Or am I remembering this incorrectly?
